rj
Post by rj on Mar 20, 2023 6:13:56 GMT -7
It looks like the rear shock has the traditional collars for adjustment. I saw the adjustment nuts for the front forks. Is there anything special here like disconnecting the harness before adjusting, etc?
Post by parthz8 on Mar 20, 2023 8:46:53 GMT -7
Main switch should be "OFF". Slide rubber cover and disconnect couplers for Ohlins for both front forks. Adjust spring preload for both front forks. Re-connect coupler back and slide the rubber cover to original position.
rj
Post by rj on Mar 20, 2023 16:39:26 GMT -7
Wow easy.
Thanks
