vulcanator
Post by vulcanator on Jan 26, 2023 18:09:03 GMT -7
Guys, It looks like I'll be able to get my 2019 MT-10 "de-catted", fit a link pipe, and do an ECU re-flash in the coming weeks. Because of the extra power gained I wanted to gear up the bike one tooth (43 to 42) on the rear by fitting the rear sprocket from the 2022 MT. Does anybody know whether this sprocket will be a straight fit onto my wheel? Thanks in advance.
bikeguyone
Post by bikeguyone on Feb 3, 2023 11:42:09 GMT -7
No actual experience but searching on-line (sprocket center. com) for replacement chain kits shows the same sprocket for the Gen 1 and Gen 2 bikes.
vulcanator
Post by vulcanator on Feb 3, 2023 12:11:16 GMT -7
After carefully checking out the parts schematic on Partzilla.com I noticed that the part number for what Yamaha calls the clutch hub (what the sprocket mounts to) is identical for for the 19 and 22 models. So I ordered the 22 rear sprocket and I'll have it Tuesday.
vulcanator
Post by vulcanator on Feb 8, 2023 8:20:55 GMT -7
Rear sprocket installed, as expected it was a straight fit. Be curious to see how much the gearing has been raised.
bikeguyone
Post by bikeguyone on Feb 11, 2023 10:23:33 GMT -7
Curious to know how your like the gearing change. Any negatives or positives based on your experience?
vulcanator
Post by vulcanator on Feb 11, 2023 11:35:40 GMT -7
Curious to know how your like the gearing change. Any negatives or positives based on your experience? I'll be taking the bike out for a short ride this afternoon to assess the changes. I expect a little improvement in the mpg dept. as Yamaha do claim a small improvement with the 2022 model. Also using the 2022 rear sprocket increases the wheelbase by 5 mm, so I'll be interested to see if I notice anything in the handling dept. too. I'll report back later.
vulcanator
Post by vulcanator on Feb 12, 2023 8:19:35 GMT -7
Curious to know how your like the gearing change. Any negatives or positives based on your experience? I'll be taking the bike out for a short ride this afternoon to assess the changes. I expect a little improvement in the mpg dept. as Yamaha do claim a small improvement with the 2022 model. Also using the 2022 rear sprocket increases the wheelbase by 5 mm, so I'll be interested to see if I notice anything in the handling dept. too. I'll report back later. Went out for a two hour ride, the roads in the PNW were a little grotty in areas that did not see the sun, so I rode accordingly. Bike steering, cornering, and handling are unchanged. I can't tell how the extra 5mm in wheelbase affects the bike. As far as speed is concerned I was unable to really open it up to its top speed, but cruising at 70 mph yields about 5200 rpm vs. around 5600-5700 rpm of the standard gearing. Pulling to redline in third would yield just over 100 mph, but with the new sprocket I'm now hitting 110 mph. Acceleration is still bonkers, but cannot determine with certainty if it's slower. Overall I'm happy to have made the change. Once I get the ECU re-flash done the extra power will certainly take advantage of the gearing.
Post by mt10orc on Feb 12, 2023 8:52:25 GMT -7
Went out for a two hour ride, the roads in the PNW were a little grotty in areas that did not see the sun, so I rode accordingly. Bike steering, cornering, and handling are unchanged. I can't tell how the extra 5mm in wheelbase affects the bike. As far as speed is concerned I was unable to really open it up to its top speed, but cruising at 70 mph yields about 5200 rpm vs. around 5600-5700 rpm of the standard gearing. Pulling to redline in third would yield just over 100 mph, but with the new sprocket I'm now hitting 110 mph. Acceleration is still bonkers, but cannot determine with certainty if it's slower. Overall I'm happy to have made the change. Once I get the ECU re-flash done the extra power will certainly take advantage of the gearing. Thanks for that update vulcanator. Please share more when u get some more time on it. I should have went for a ride yesterday as well beautiful on the coast yesterday.
vulcanator
Post by vulcanator on Mar 11, 2023 20:35:53 GMT -7
bigpoppanoos
Post by bigpoppanoos on Mar 11, 2023 20:56:45 GMT -7
Man, that looks awesome! How loud is it? I have been debating for months about doing the decat. I like the look of yours a lot.
vulcanator
Post by vulcanator on Mar 11, 2023 21:33:52 GMT -7
Man, that looks awesome! How loud is it? I have been debating for months about doing the decat. I like the look of yours a lot. The bike is louder than stock, but not overly so, and still delivers a throaty sound. I live in a quiet neighborhood so I keep the revs down until I’m on the main road. I think the de-cat is a good way to go. The weight savings are impressive and the power boost you get is great value for about a $600 investment.
bigpoppanoos
Post by bigpoppanoos on Mar 11, 2023 21:49:42 GMT -7
Thanks man! I like the look of that pipe a lot more than the Leo Vince most people seem to do.
vulcanator
Post by vulcanator on Mar 11, 2023 21:55:36 GMT -7
Thanks man! I like the look of that pipe a lot more than the Leo Vince most people seem to do. Totally agree, the Leo Vince pipe aesthetically has a look only its mother would love. That was the main reason I chose the Scorpion.
bigpoppanoos
Post by bigpoppanoos on Mar 11, 2023 22:15:23 GMT -7
Nice. Did you ride it around at all before you had it flashed? Just curious how it felt. I just have the Yosh MT-10 slip on on my bike right now. I think I'm going to have to order this link pipe, it would look nice with the slip on.
vulcanator
Post by vulcanator on Mar 11, 2023 22:20:27 GMT -7
Nice. Did you ride it around at all before you had it flashed? Just curious how it felt. I just have the Yosh MT-10 slip on on my bike right now. I think I'm going to have to order this link pipe, it would look nice with the slip on. I only rode it in its stock form, but geared up. If I recall correctly, the Scorpion link pipe works only with the stock can, or Scorpion can. You can verify that on their website.
bigpoppanoos
Post by bigpoppanoos on Mar 11, 2023 22:28:29 GMT -7
Awesome, thanks man. I think it would work with my slip on, it's the Yamaha Yosh pipe that fits directly on the stock cat pipe without any mods. I know people have used the Leo Vince pipe with the same slip on, so I'm thinking it should fit. You mind if I ask where you ordered it?
vulcanator
Post by vulcanator on Mar 11, 2023 22:39:36 GMT -7
Awesome, thanks man. I think it would work with my slip on, it's the Yamaha Yosh pipe that fits directly on the stock cat pipe without any mods. I know people have used the Leo Vince pipe with the same slip on, so I'm thinking it should fit. You mind if I ask where you ordered it? Motosport.com
bigpoppanoos
Post by bigpoppanoos on Mar 11, 2023 22:46:51 GMT -7
Much appreciated!
vulcanator
Post by vulcanator on Apr 30, 2023 16:22:14 GMT -7
Curious to know how your like the gearing change. Any negatives or positives based on your experience? I'll be taking the bike out for a short ride this afternoon to assess the changes. I expect a little improvement in the mpg dept. as Yamaha do claim a small improvement with the 2022 model. Also using the 2022 rear sprocket increases the wheelbase by 5 mm, so I'll be interested to see if I notice anything in the handling dept. too. I'll report back later. As promised, I done a few rides and have a better sense of how the sprocket change has panned out. The handling of the bike to me is unchanged, the big thing to me has been the fuel consumption. I have de-catted my bike and had it dyno tuned by EDR Performance in Beaverton, Oregon. I performed a 330 mile ride yesterday on two lane roads averaging between 60-80 once out of town with the occasional no holds barred grip it and rip it for passing. I reached 142 miles before the fuel gauge started to flash. I rode the bike for a further 25 miles before refueling. The bike accepted 4.2 gallons for an average fuel consumption of 39.7 mpg. So, it's clear to me that gearing the bike up was a good thing.
Post by mt10orc on Apr 30, 2023 19:41:56 GMT -7
Nice update really appreciate it. It was beautiful yesterday. Got a little putt in. Let the wife get out while I took care of the grandkid and friend.
