jdmt10
Post by jdmt10 on Nov 27, 2022 18:01:42 GMT -7
I have a very slight wobble in the rear wheel almost unnoticeable. I only notice it after picking up the bike on a rear stand to check and adjust chain slack.. adjustment is good and seems to be inline .. any ideas on what going on or should I not even worry about it ... lmk thank in advance im goingnto try to upload a video to thread
jdmt10
Post by jdmt10 on Nov 27, 2022 18:08:28 GMT -7
Post by mt10orc on Nov 27, 2022 20:46:57 GMT -7
I have a very slight wobble in the rear wheel almost unnoticeable. I only notice it after picking up the bike on a rear stand to check and adjust chain slack.. adjustment is good and seems to be inline .. any ideas on what going on or should I not even worry about it ... lmk thank in advance im goingnto try to upload a video to thread I take it you haven’t had any hard impacts on the wheel? You can see the slight wobble on the whole wheel. It’s a new bike right? Might be something you should have shop look at if under warranty. It look like the wheel itself is a bit off kilter. Not spinning it fast enough to show a wheel balance issue but it could be if it really out of balance.
jdmt10
Post by jdmt10 on Nov 28, 2022 3:40:04 GMT -7
I have a very slight wobble in the rear wheel almost unnoticeable. I only notice it after picking up the bike on a rear stand to check and adjust chain slack.. adjustment is good and seems to be inline .. any ideas on what going on or should I not even worry about it ... lmk thank in advance im goingnto try to upload a video to thread I take it you haven’t had any hard impacts on the wheel? You can see the slight wobble on the whole wheel. It’s a new bike right? Might be something you should have shop look at if under warranty. It look like the wheel itself is a bit off kilter. Not spinning it fast enough to show a wheel balance issue but it could be if it really out of balance. I recently had to change the tire at about 500 miles due to a puncture. And as for balance I have balance beads in it those are supposed to be fool proved. I'll have a shop look at it as soon as possible thanks!
Post by Deleted on Nov 28, 2022 7:59:10 GMT -7
Its fine dont stress about it.
My wheel looked like that from day 1 and still does even after changing sprockets and chain.
After thousands of miles and dozens of track days it has never been an issue even once for me.
Post by RedAndBlack on Nov 28, 2022 17:28:33 GMT -7
Doesn't look crazy out of spec to me
Check your chain tightness. I couldn't completely see it but maybe a little tight.
Also, some members have reported popping a check engine light from running their bike on the rear stand. Might wanna be careful with that. Or hopefully they fixed that by now.
jdmt10
Post by jdmt10 on Feb 14, 2023 22:51:09 GMT -7
Update this wobble was due to a broken bearing .. broken bearing was due to a "tech" leaving a spacer out of the rear rim I believe the one in back of the sprocket.. long story short my abs sensor was damaged my bearing was cracks and cause the issue all.do to a simple tire puncture
Post by willl84 on Feb 15, 2023 4:40:42 GMT -7
Update this wobble was due to a broken bearing .. broken bearing was due to a "tech" leaving a spacer out of the rear rim I believe the one in back of the sprocket.. long story short my abs sensor was damaged my bearing was cracks and cause the issue all.do to a simple tire puncture I hope the shop fixed it right and replaced the parts for free!
Post by parthz8 on Feb 26, 2023 5:25:10 GMT -7
Update this wobble was due to a broken bearing .. broken bearing was due to a "tech" leaving a spacer out of the rear rim I believe the one in back of the sprocket.. long story short my abs sensor was damaged my bearing was cracks and cause the issue all.do to a simple tire puncture Crazy!! But good you found the fix! Local tire shop did exactly this mistake when i went to replace my rear R1M tire. Fortunately i took picture of every part while disassembling and pointed out when he was putting tire back that "Spacer" was missing! Technician tried to deny but ultimately found spacer rolled to one side of shop wall...
