Post by stoltecmoto on Dec 5, 2016 13:47:18 GMT -7
  You read that right - the LH side stator cover is hot off the presses. While the RH side ignition cover was the same as the R1, the LH side stator cover is deeper on the -10 to accommodate the larger flywheel. After a few months of prototypes, we're finally ready to move these along. Both covers are constructed from billet aluminum and are hard coat anodized black for corrosion protection and good looks. As always, fully manufactured here in the USA. Bolts on in minutes! FZ-10 Woodcraft Engine Cover | StoltecMotoNow through the end of the year, use the coupon code WOODCRAFT and get free shipping within the United States
bogie
Post by bogie on Dec 5, 2016 14:09:27 GMT -7
Ordered!!!
Post by stoltecmoto on Dec 5, 2016 14:11:54 GMT -7
bogie
Post by bogie on Dec 10, 2016 10:34:32 GMT -7
GOT MINE!!! Thanks for the Speedy Service Nick!!! Now if it wasn't butt ass cold out and snowing!!! LOL Mounting and install tech tip will have to wait till weather warms up.
bogie
Post by bogie on Jan 18, 2017 20:10:19 GMT -7
Mounted!!
latte
Post by latte on Mar 20, 2017 8:03:40 GMT -7
These look great! I've seen right-side case covers for the clutch as well, do they seem useful? Or is the clutch recessed enough compared to the right-side ignition cover that it's not needed?
bogie
Post by bogie on Mar 20, 2017 9:32:18 GMT -7
I would say the ignition cover would do good on keeping the clutch safe
landmark518
Post by landmark518 on Mar 23, 2017 13:43:55 GMT -7
I would say the ignition cover would do good on keeping the clutch safe Hey Bogie, did you ever post a mounting and install tech tips for these?
bogie
Post by bogie on Mar 23, 2017 14:35:55 GMT -7
I would say the ignition cover would do good on keeping the clutch safe Hey Bogie, did you ever post a mounting and install tech tips for these? Sorry no but it really is very simple. Take bolts out on motor where covers go. Put on cover and use the supplied replacement bolts with a little blue loctite.
