jonnyblayz
Post by jonnyblayz on Sept 15, 2022 6:18:26 GMT -7
Looking on eBay, I’ve seen some used Ohlins rear shocks from mt10 sp’s. Has anyone installed one? There are some electrical connections on the shock. I didn’t notice any electrical connections on my current one.
There are for gen 1.
Post by hooli on Sept 15, 2022 8:32:58 GMT -7
Unless you have the shock altered for manual use, it generally won't work since it's for the SP model. It has electronically-drive valving that is ordinarily closed until the valves are energized. It'll bolt up fine but with the fluid circuits closed you'll wind up with no travel; your bike will basically be a hard-tail. You'd be much better off just buying an aftermarket shock for the standard MT-10. Several manufacturers make replacement shocks for non-SP models. I'm running a Penske shock myself.
jonnyblayz
Post by jonnyblayz on Sept 15, 2022 10:52:28 GMT -7
That’s kind of what I was thinking. Too bad because I found a couple for less than $500.
