dumbguyon1000cc
Post by dumbguyon1000cc on Sept 8, 2022 17:36:57 GMT -7
hello, i recently finally got my cat removed and the ecu flashed as well.
Holy shit, now this is the bike I subscribed to when I bought it. It went from pretty chill- holy smokes, weeeeeeee. And i only slapped a leovince decat with the stock can. The most entertaining part is how hard the deceleration pop of this bike is so far. I haven't had a huge dumb, shit eating grin this large that I broadcast through my clear visor to the guy besides me at a stoplight.
Can someone explain to me about decel popping, the problems around it and why I should get a backplate?
my exhaust note with stock + leovince is quite tame but the huge POP seems to be way too addictive to remove. Am i just being obnoxious or is the mt10 specifically very good at doing this?
Post by willl84 on Sept 9, 2022 3:52:49 GMT -7
If you got the ECU flashed it shouldn't be popping at all as they typically disable the AIS valve so it stays closed all the time
Post by clayton on Sept 9, 2022 4:37:50 GMT -7
Had mine flashed by 2wdw and went with the ftecu active tune with a 3/4 yoshi exhaust and I have absolutely no popping on deceleration!
Post by mt10orc on Sept 9, 2022 6:51:24 GMT -7
If you got the ECU flashed it shouldn't be popping at all as they typically disable the AIS valve so it stays closed all the time +1 My 2020 has the AIS in the default closed position from my ECU flash by 2WDW.
dumbguyon1000cc
Post by dumbguyon1000cc on Sept 9, 2022 13:39:10 GMT -7
If you got the ECU flashed it shouldn't be popping at all as they typically disable the AIS valve so it stays closed all the time Am I losing power with decel popping?
Post by mindcrime79 on Sept 9, 2022 13:52:53 GMT -7
I think you mean/need block off plates.
Post by willl84 on Sept 10, 2022 2:50:39 GMT -7
If you got the ECU flashed it shouldn't be popping at all as they typically disable the AIS valve so it stays closed all the time Am I losing power with decel popping? No but some say it might hurt your exhaust valves over time
semprenissart
Post by semprenissart on Sept 11, 2022 9:38:17 GMT -7
If you got the ECU flashed it shouldn't be popping at all as they typically disable the AIS valve so it stays closed all the time +1 My 2020 has the AIS in the default closed position from my ECU flash by 2WDW. I had the same flash done on my MT09 after putting a full exhaust system Akra and had popping on decel. contacted 2wdw and they told me putting block off plates will stop it (even though they disabled the AIS valve in the flash). After putting block off plates it was fine. I still don’t understand why I had popping if the AIS was disabled or they thought they did but actually didn’t?
Post by mt10orc on Sept 11, 2022 20:05:21 GMT -7
+1 My 2020 has the AIS in the default closed position from my ECU flash by 2WDW. I had the same flash done on my MT09 after putting a full exhaust system Akra and had popping on decel. contacted 2wdw and they told me putting block off plates will stop it (even though they disabled the AIS valve in the flash). After putting block off plates it was fine. I still don’t understand why I had popping if the AIS was disabled or they thought they did but actually didn’t? Not sure if your MT-09 AIS is in default closed position like the 2020 MT-10. I confirmed that the AIS was default closed with 2WDW when I got my flash. I can’t say every production year is default closed as I only inquired about 2020. Don’t have any decel backfire on my bike.
Post by willl84 on Sept 12, 2022 4:44:15 GMT -7
+1 My 2020 has the AIS in the default closed position from my ECU flash by 2WDW. I had the same flash done on my MT09 after putting a full exhaust system Akra and had popping on decel. contacted 2wdw and they told me putting block off plates will stop it (even though they disabled the AIS valve in the flash). After putting block off plates it was fine. I still don’t understand why I had popping if the AIS was disabled or they thought they did but actually didn’t? If the AIS valve doesn't fully seal shut for whatever reason it could let air in and still allow the popping
