nofi
Post by nofi on Aug 31, 2022 22:13:18 GMT -7
I have 2022 MT-10 with 1,000 miles on it. Occasionally under moderate to hard acceleration, I hear a pop sound from the exhaust when I come off the throttle between shifts. Is this normal? It does not sound like a backfire.
Post by mt10orc on Aug 31, 2022 22:49:51 GMT -7
I have 2022 MT-10 with 1,000 miles on it. Occasionally under moderate to hard acceleration, I hear a pop sound from the exhaust when I come off the throttle between shifts. Is this normal? It does not sound like a backfire. Yes that is normal. I take it you not using the Quick shifter when this occurs?
nofi
Post by nofi on Aug 31, 2022 22:58:31 GMT -7
Yes you are correct. I am not using the Quick Shifter. Thanks much for the quick response!
jmm0122
Post by jmm0122 on Sept 1, 2022 12:23:50 GMT -7
My 2022 does this as well. Pretty sure it has to do with the AIS system ejecting air into the exhaust system. That's honestly the only noise I ever hear out of the exhaust. These bikes are so quiet.
