Post by parthz8 on Aug 12, 2022 14:06:50 GMT -7
Any links or suggestion for gold quality foldable fender license plate eliminator for MT-10 (2021)? I am looking for something on which i can fix OEM turn signal and able to fold the license plate.
Post by rracerfz10 on Sept 6, 2022 5:31:07 GMT -7
Post by willl84 on Sept 6, 2022 6:17:30 GMT -7
I have that kit. It doesn't fold
Post by parthz8 on Sept 6, 2022 12:46:40 GMT -7
Unfortunately here speed cameras are notorious (nothing against law), but single flash over 12mph cost $165 and it doubles with every 12mph...so i badly need foldable fender license plate eliminator for MT-10 (2021). Already got one for my R1M from China with integrated brushed LED turn signals (with OEM connectors)
Post by mt10orc on Sept 6, 2022 21:34:36 GMT -7
Unfortunately here speed cameras are notorious (nothing against law), but single flash over 12mph cost $165 and it doubles with every 12mph...so i badly need foldable fender license plate eliminator for MT-10 (2021). Already got one for my R1M from China with integrated brushed LED turn signals (with OEM connectors) Remind me if I’m ever in UAE to not speed.
Post by parthz8 on Sept 7, 2022 13:30:25 GMT -7
mt10orc cops wont chase you here for speeding, that job is done by millions of cameras and specially hidden ones...
Post by mt10orc on Sept 7, 2022 16:38:01 GMT -7
Thus the reason for a foldable license plate inquiry. :-)
Post by Deleted on Sept 7, 2022 18:28:35 GMT -7
They are easy to get on eBay.
Post by parthz8 on Sept 8, 2022 11:10:39 GMT -7
They are easy to get on eBay. I check on eBay but none shows complete compatibility with MT-10, some which are compatible doesn't show if foldable..
maxxj
Post by maxxj on Sept 8, 2022 16:06:12 GMT -7
Mine came with a fender eliminator kit that the plate part was bent in slightly for that reason. There are no cameras around where I live so I just bent it back out. Are you looking for one that has different positions or just one that you can push the plate back?
Post by parthz8 on Sept 14, 2022 15:23:48 GMT -7
Mine came with a fender eliminator kit that the plate part was bent in slightly for that reason. There are no cameras around where I live so I just bent it back out. Are you looking for one that has different positions or just one that you can push the plate back? I am looking for one that i can push the plate back. fender eliminator should also have slot to mount OEM indicators. Yours is with slots?
mfz10
Post by mfz10 on Sept 15, 2022 2:36:22 GMT -7
007plate.com sells a carbon fiber one that also a motorized license plate flipper. Their gadget is universal, you just have to remove the stock license plate bracket and mount he gadget onto the under tail of the bike Here it is on an R1
maxxj
Post by maxxj on Sept 18, 2022 4:39:36 GMT -7
Mine came with a fender eliminator kit that the plate part was bent in slightly for that reason. There are no cameras around where I live so I just bent it back out. Are you looking for one that has different positions or just one that you can push the plate back? I am looking for one that i can push the plate back. fender eliminator should also have slot to mount OEM indicators. Yours is with slots? Sorry for the late response, I don't have notifications on here. I don't know what brand mine is because it came with it but if it's like anything else the PO did to this bike then it's stuff he got off ebay. The plate bracket and turn signal bracket are two separate pieces that stack and get bolted up to the subframe. Here's a couple pictures if you want them. Worth mentioning that my turn signal bracket is also bent down a little bit to accommodate the luggage. I've seen some big rigs get busted with flip up plates by the way. Having it tilted for cameras is one thing but having a whole system like that 007 thing is just showing the police that pulls you over that you're trying to act a fool.
