danny230992
Post by danny230992 on Jul 3, 2022 5:43:06 GMT -7
Hi guys I’m have a question how I can block or something my modes for example in B or STND my switch mode is so sensitive I need to know if somebody can help me with that thanks
Post by mt10orc on Jul 3, 2022 8:53:48 GMT -7
So describe what is happening while riding? Is your mode switching when decelerating? Have you taken the switch apart to see what may be a cause?
danny230992
Post by danny230992 on Jul 3, 2022 9:36:55 GMT -7
this happens decelerating And never check this button or switch
Post by mt10orc on Jul 3, 2022 10:13:52 GMT -7
this happens decelerating And never check this button or switch I would take the handle switch off and see if you can check to see if something is loose inside the switch. I’ve not taken this apart before but maybe you can check it off the bike and determine why it is so sensitive. If you need it replaced believe this is the part you require. B67-83963-00-00 HANDLE SWITCH item 16 in diagram. The switch should have resistance and not be loose. A spring I’m guessing.
danny230992
Post by danny230992 on Jul 3, 2022 18:57:22 GMT -7
Yeah I have to try something asap cause I wanna do differents maps when I ride and now is imposible
Post by mt10orc on Jul 3, 2022 19:35:01 GMT -7
Yeah I have to try something asap cause I wanna do differents maps when I ride and now is imposible Let us know how it goes.
Post by RedAndBlack on Jul 3, 2022 23:39:26 GMT -7
Similarly, There's a recall on the MT 10 brake light switch where something about the silicone in the switch can cause increased resistance and make the brake light work in an unexpected manner.
I wouldn't be surprised if there's a similar issue that effects the other switches.
The recall recommends brake light switch replacement so if it's the same issue, you might need to replace that switch.
Probably not a bad idea to crack the switch open and inspect it as others suggested.
Post by mt10orc on Jul 4, 2022 7:14:31 GMT -7
Similarly, There's a recall on the MT 10 brake light switch where something about the silicone in the switch can cause increased resistance and make the brake light work in an unexpected manner. I wouldn't be surprised if there's a similar issue that effects the other switches. The recall recommends brake light switch replacement so if it's the same issue, you might need to replace that switch. Probably not a bad idea to crack the switch open and inspect it as others suggested. Good to know about the switch recall. www.advrider.com/yamaha-recalls-over-18000-bikes-for-faulty-front-brake-switch/
