andresdanielbr
Post by andresdanielbr on May 25, 2022 11:23:19 GMT -7
Hey guys, so I was riding yesterday when my check engine light came on then. Then a few minutes later my abs and traction control lights came on, and my wick shifter stopped working. However the bike sounded okay and ran just fine, I just can’t figure out what’s wrong anything helps. Thanks!
Post by RedAndBlack on May 26, 2022 1:18:55 GMT -7
Is there anything done to the bike recently? Tire change? Make sure the front wheel isn't on backward. Wheel sensor is only on one side and is a Wheel sensor is only on one side. Also check the wheel sensors, make sure they are slotted and lined up correctly.
These are typical causes of ABS and TCS failure
Post by willl84 on May 26, 2022 5:33:10 GMT -7
Check your battery first. Low voltage can cause all sorts of strange problems. Check it with the bike off and then check it with the engine around 2500RPM. You should be 14VDC+ at the terminals but not over 15VDC. Over 15 = bad regulator, not charging = bad stator or rectifier.
terrys
Post by terrys on May 26, 2022 15:50:17 GMT -7
If the ABS and TCS warnings are on, that would suggest you have an issue with a wheel speed sensor. Maybe try cleaning around these first, then checking that any connectors for the sensors are intact/no wire damage. Or just connect an ODBDII device and clear the fault code, then see if it comes back.
Croustibat
Post by Croustibat on May 31, 2023 13:41:06 GMT -7
Did you solve your issue ? I have the exact same problem.
I'm going to take a look at the ABS sensors.
