slangblades
Post by slangblades on May 23, 2022 17:09:52 GMT -7
The rotor is scrathed up, will I need to replace it, is it possible harder pads will flatten it without issue?
Any suggestions for good brake pads (and rotor if needed)?
How difficult would it be to do the change myself? Ive only changed pads on a car before and when I did, they brakes felt weak so I ended up having to take it into a shop to fix that. I guess I had to bleed the brakes or something like that. That's where I begin to get lost...
slangblades
Post by slangblades on May 23, 2022 17:17:26 GMT -7
minlak
Post by minlak on May 23, 2022 17:42:07 GMT -7
Ok couple of things here - run your fingernail across the rotor how grooved is it? If there is a lot of grooves or deep grooves you should get it machined or replace it - You also need to measure the width of the rotor as there is a minimum width and you may have worn it down too far - If you don't machine or replace the new pads will not get full braking force (they may eventually bed in but not ideal) - Asking if something is easy is so subjective - I think it is easy the only trick is sometimes they can be painful to align back up to put the bolts in other times they just fall into place - You undo 2 bolts remove the caliper - push the pistons back in and fit the new pads using the spacers etc . As you let it get so low though you need to double check the seals etc and I would clan around the pistons before pushing them back in - Also make sure you dont overflow the back reservoir as fluid may have been added if it looked low at a service - If your bike is 2 yrs old it should have the fluid replaced anyway. I would suggest if you are not confident doing it - In this instance it may pay to go to a shop and get their opinion on replacing the rotor ad getting them to do the work.
Post by willl84 on May 24, 2022 5:33:57 GMT -7
Post by rracerfz10 on May 27, 2022 6:17:27 GMT -7
Yeah you need to replace that like willl84 said. Also typically cross drilled rotors can't be turned anyway.
Post by Deleted on May 27, 2022 6:41:55 GMT -7
Dont usually hear about people wearing the rear brake pad down like that especially enough to dig into the rotor.
I very rarely use the rear brake, you must be using the crap out of it!
Post by willl84 on May 27, 2022 6:51:03 GMT -7
Dont usually hear about people wearing the rear brake pad down like that especially enough to dig into the rotor. I very rarely use the rear brake, you must be using the crap out of it! With all the engine braking on this beast I use my rear 90% of the time. I hardly touch my fronts for daily commuter riding lol
Post by RedAndBlack on May 27, 2022 23:28:40 GMT -7
Dont usually hear about people wearing the rear brake pad down like that especially enough to dig into the rotor. I very rarely use the rear brake, you must be using the crap out of it! Thats a recipe for disaster
