oni
Post by oni on Mar 24, 2022 18:33:04 GMT -7
Hello gentlemen, Replaced a tire on the rear today, pads came out of rear caliper. Put them back with spring. Seems to be in correct orientation? But now when on the rear brake it feels fine when lightly on it but when you bear down on it I can feel a clunk like sensation and hear a noise like a grind type noise. Like the pads are shuttering or something. This can’t be ABS can it? I checked torque on all bolts too I’m a bit stumped Brake caliper spring was inserted with thicker side on plunger side. Can’t think of anything else it could be. Any help Is very welcome!! 2020 MT-10 , 3k on the odometer. Thank you!
Post by RedAndBlack on Mar 24, 2022 20:04:20 GMT -7
Did you slot the rear brake caliber into the swingarm correctly? If you didn't it can actually move back and forth and may be the source of the clunk. ABS is more of a pulsating vs a clunking. My money's on something is wrong. best bet is to take everything back apart and whip out the service manual and go step by step, both for removing and replacing the rear brake pads and for reinstalling the tire. I would try to push the brake piston in as much as you can when you remove and then reseat the brake pads. And take care to put the brake pads in correctly with that metal clip piece. I've screwed that up before myself.
I know it's expensive but the pitbull tire wedge is a godsend if you change your own tires. Even without a pitbull stand, it's worth the $80 or whatever it may cost now. Definitely a great Christmas gift from the wifey. 😀
oni
Post by oni on Mar 24, 2022 22:18:45 GMT -7
Thank you for the quick response, I feel the same it must be something out of alignment. It was just high hopes it was ABS but it doesn’t feel right I know what ABS feels like.
I will disassemble again and see if I can find anything. The bracket you mentioned I didn’t double check just the caliper once I heard the noise I removed it to check. It’s just strange it is perfectly smooth until you really bear down on the pedal.
Those little clips are not my favorite part of a brake job lol.
That pitbull tire lift is SWEET! I want it. I have 2 pitbull sets but haven’t seen that before.
Post by RedAndBlack on Mar 25, 2022 11:35:13 GMT -7
It's so great. Made what was sometimes a 30-45 minute battle of endurance full of frustration to a fairly simple and quick procedure.
oni
Post by oni on May 15, 2022 22:30:54 GMT -7
Old thread revival : I have fully taken the rear wheel off and put it back together and still have the clunk the caliper bracket is for sure slotted into the swing arm fully. Any ideas? Or I’ll be taking it into the shop for something probably really stupid. No signs of wear or movement when taken apart The rear caliper does wiggle a little but I noticed all my others bikes do this as well. Any help is very very welcome Thank you!
Post by mt10orc on May 15, 2022 22:52:07 GMT -7
Money well spent when messing with axels. I use it with my woodcraft lifts. Sorry wish I had an answer to your clunking issue.
oni
Post by oni on May 16, 2022 14:03:39 GMT -7
I did buy one of the Pitbull tire jacks. Awesome item . Thanks anyways I’m just really stumped by this clunk. Bike seems fine otherwise.
weehe
Post by weehe on May 16, 2022 14:57:21 GMT -7
Dumbest thing I did on a FZ6 was forget to put the bearing spacer back in after getting a new tire. Would ride fine for 500 miles then start clanking. Replaced the rear wheel bearing twice before realizing it.
oni
Post by oni on May 16, 2022 20:54:18 GMT -7
Dumbest thing I did on a FZ6 was forget to put the bearing spacer back in after getting a new tire. Would ride fine for 500 miles then start clanking. Replaced the rear wheel bearing twice before realizing it. Working on bikes is a learning process sometimes I am not ashamed to admit lol
Post by RedAndBlack on May 16, 2022 23:37:27 GMT -7
Based on the sound starting with initially taking the rear wheel off, I still feel like something is amiss with the reinstall. Did you go step by step with the service manual? Maybe consider taking it to a shop? Make sure all spacers are in the right place. Make sure cush drive was reinstalled and done correctly?
Only other idea I have, what about your chain and sprockets? Are they worn? Could be clunking from the chain skipping teeth.
oni
Post by oni on May 17, 2022 0:19:05 GMT -7
I appreciate your info, I did follow the manual step by step and tire was replaced but I didn’t touch the cush drive. It all looked correct. Chain and sprocket are both in good shape. I will take it to a shop and update here with what they find out. It’s so weird it only does it when braking hard on the rear. Light pedal all feels fine. Strange I can’t find anyone else experiencing this before lol
mt1021
Post by mt1021 on May 17, 2022 15:55:36 GMT -7
Take a pic of your setup including caliper brace to swingarm and pads. That would help in understanding what the problem would be.
oni
Post by oni on May 19, 2022 12:34:23 GMT -7
Take a pic of your setup including caliper brace to swingarm and pads. That would help in understanding what the problem would be. I’ll do it! I’ll snap some of the rear wheel / pads / swing arm and wheel the best I can.
oni
Post by oni on May 22, 2022 14:57:16 GMT -7
oni
Post by oni on May 25, 2022 17:11:45 GMT -7
Any opinions welcome
Post by RedAndBlack on May 26, 2022 1:13:45 GMT -7
I got nothing from the pictures. Everything looks good.
Maybe it is ABS? I'm assuming it only happens when you're on the rear brake? Is it happening under light braking? Can you duplicate it on the rear stand (Don't do this with the bike on, it'll throw a code)?
Your bike seems to be too new to be something like a wheel bearing or warped rotor.
How about the chain? Not too tight or not too loose?
oni
Post by oni on May 26, 2022 8:52:56 GMT -7
Chain is adjusted to spec, well that’s partially good news lol I can’t get to replicate on the stand (not running) it is a new tire so maybe abs is kicking in easier than with the old one? Only happens when I solidly get on the rear. Thanks for taking a look
Post by willl84 on May 26, 2022 11:25:32 GMT -7
Only happens when I solidly get on the rear. It's the ABS. Pull the ABS fuse and do the same and see what happens. I notice that the rear ABS kicks in on my 2019 way sooner than I expect it to. I've gotten harder on rears on other bikes and not had any lockup, maybe it's just a suspension geometry thing on these bikes.
oni
Post by oni on May 26, 2022 13:57:41 GMT -7
Only happens when I solidly get on the rear. It's the ABS. Pull the ABS fuse and do the same and see what happens. I notice that the rear ABS kicks in on my 2019 way sooner than I expect it to. I've gotten harder on rears on other bikes and not had any lockup, maybe it's just a suspension geometry thing on these bikes. That’s a phenomenal idea thank you! Probably would be good to know where the fuse is anyways, someday I’d like to take her to the track. That’s what had me so confused is my rear brake on my ZX6R you can get on hard with no abs chatter or anything.
Post by parthz8 on May 26, 2022 14:41:29 GMT -7
Hi Oni, I will get some pictures from my MT10 (Rear Brake) and Wheel for you to refer this weekend. See below ref. diagram to find ABS system.
