gary4279
Post by gary4279 on Nov 22, 2021 20:23:32 GMT -7
Hello everybody,I want to change the oil cooler part,I need to Release the oil and then disassemble?
Post by willl84 on Nov 23, 2021 6:20:59 GMT -7
Just put a drain pan under the cooler and catch any that might drip out. I'd also replace the two o-rings (#7 and #10) while you're swapping the cooler
Edit: also be sure to recheck your oil level after you start it as it will need to fill the new oil cooler with oil
