thepianoman77
Post by thepianoman77 on Oct 14, 2021 18:59:58 GMT -7
Hey, I noticed theat a lot of people have flashed your ECU with flash tune using a 2WDW map... How many of you have gotten the download from 2WDW and done it yourselves? If so, have you gotten the message "invalid ECU image" ? I am having this issue. Nel said to just keep trying to flash it... but this is not working for me. I was hoping someone here could shed some light if you have gone through the same experience. My ECU part number is -51, so Nel said to flash the stock -50 and then flash his map... that didn't work. I've restarted my computer, restarted the program, flashed stock -50 and -51 before Nel's map, flashed unrestricted -50 and -51 before Nel's map. Nothing seems to be working. Any help, PLEASE!!!🙏🙏🙏
Post by Deleted on Oct 15, 2021 5:37:17 GMT -7
I suggest just mailing them the ECU and letting them flash it.
thepianoman77
Post by thepianoman77 on Oct 15, 2021 9:52:30 GMT -7
I suggest just mailing them the ECU and letting them flash it. Can't do that, since it's my only mode of transportation atm lol. So I need my bike for work and can't wait 2 weeks for my ecu.
jm1
Post by jm1 on Oct 23, 2021 2:47:15 GMT -7
I would contact FT ECU directly as the problem doesn't seem related to the map itself, but the compatibility with your ECU version and possibly the flashing software.
Post by hooli on Oct 23, 2021 14:26:32 GMT -7
2WDW has downloadable maps? That's a first.
thepianoman77
Post by thepianoman77 on Oct 26, 2021 16:27:06 GMT -7
It's all fixed now. 🙂 Ya, 2WDW can send you a map to flash if you have the flashtune software and flashing harness. (the actual map is locked and can't be seen or modified)
