motoxr392
Post by motoxr392 on Oct 3, 2021 7:59:57 GMT -7
I'm trying to import the Dynojet PCV LeoVince midpipe/slipon file into FTECU. When I use the import feature, the FTECU software reads "negative" values from the PCV map, and inputs "0" values into the fuel tables. So, the bike will idle, but immediately dies with any throttle. Has anyone found a fix? A couple screenshots are below.
Thanks
