Post by mindcrime79 on Sept 24, 2021 11:18:03 GMT -7
Anyone notice that the clutch cable is real tight when handlebars are turned to full left position? Is there a way to adjust this or is this normal?
Post by parthz8 on Sept 24, 2021 14:02:43 GMT -7
Anyone notice that the clutch cable is real tight when handlebars are turned to full left position? Is there a way to adjust this or is this normal? This is something i want to check on my MT-10 when bike is suspended and front wheel is free to rotate. I remembering reading it hear: bike going towards right if clutch cable it tight and it was readjusted to resolve this issue... Are you facing any riding issue?
Post by mindcrime79 on Sept 24, 2021 15:15:15 GMT -7
No riding issues. Just don't like how tight it is at full lock.
weehe
Post by weehe on Sept 25, 2021 8:18:07 GMT -7
No riding issues. Just don't like how tight it is at full lock. Try pulling it up towards the bars. I noticed over time mine would slide down and bind a bit like you are seeing. Basically pull the slack back up.
Post by sdshawn on Sept 25, 2021 13:11:01 GMT -7
I had to reroute my cable it was binding up and pinched down by the fake scoop so much that plastic insulation wore down to steel. It's free flowing now and no issue's when bars are turned now also.
Post by mindcrime79 on Sept 25, 2021 22:30:23 GMT -7
No riding issues. Just don't like how tight it is at full lock. Try pulling it up towards the bars. I noticed over time mine would slide down and bind a bit like you are seeing. Basically pull the slack back up. Ah... simple fix thank you!
ash919
Post by ash919 on Nov 9, 2022 17:24:59 GMT -7
I had to reroute my cable it was binding up and pinched down by the fake scoop so much that plastic insulation wore down to steel. It's free flowing now and no issue's when bars are turned now also. Do you remember how you routed it? Thanks
Post by mindcrime79 on Nov 9, 2022 17:39:43 GMT -7
I feel like every few rides I have to pull it up and re adjust it. I zip ties it up in that position seems to be working...
Post by parthz8 on Nov 10, 2022 10:51:51 GMT -7
I feel like every few rides I have to pull it up and re adjust it. I zip ties it up in that position seems to be working... Please you you provide more details how you do it? I want to do it on my MTs....
