vullnet
Post by vullnet on Aug 28, 2021 10:52:59 GMT -7
been debating getting new sprockets, either 18/45 or 20/45 to achieve a higher top speed. Was wondering if anyone has done these before and which they'd recommend, I know I'll lose some low end torque but I was curious if anyone has experience with it. As far as power wheelies, launch speed, etc.
chmt
Post by chmt on Aug 28, 2021 17:09:31 GMT -7
Your ratios don't make sense. If you want higher top speed you need taller gearing so why would you increase the rear sprocket size? The higher the top speed the more stability you you need so a longer wheelbase would help. Try leaving the front sprocket stock or up one tooth max and go with a smaller rear sprocket such as a 41T.
vullnet
Post by vullnet on Aug 28, 2021 18:08:55 GMT -7
Your ratios don't make sense. If you want higher top speed you need taller gearing so why would you increase the rear sprocket size? The higher the top speed the more stability you you need so a longer wheelbase would help. Try leaving the front sprocket stock or up one tooth max and go with a smaller rear sprocket such as a 41T. I'm not too much of an expert on ratios, just talked with a dude who knows more than me and thats what he suggested.
Post by dkim213 on Aug 28, 2021 23:38:34 GMT -7
been debating getting new sprockets, either 18/45 or 20/45 to achieve a higher top speed. Was wondering if anyone has done these before and which they'd recommend, I know I'll lose some low end torque but I was curious if anyone has experience with it. As far as power wheelies, launch speed, etc. You might theoretically hit a higher top speed with a higher ratio (numerically lower), but you’re probably power limited.
