bmwd40
Post by bmwd40 on Aug 20, 2021 10:05:18 GMT -7
Any one use Vcyclenut to flash thier ECU? If so how did it perform?
mclovin
Post by mclovin on Aug 20, 2021 12:33:31 GMT -7
Yes. Did my FJ 09 and my MT 10. His flashes are excellent. His service is excellent. Call him up. If he doesn't answer, he'll call you back quickly. Ask him whatever you want. If you want something customized he'll do it. I went with his base flash and it's great. He's developed his maps over years so he will flash your ECU and ship it out the same day.
bmwd40
Post by bmwd40 on Aug 20, 2021 13:50:06 GMT -7
Thanks. Good to know that you had a good experiance.
blueblur
Post by blueblur on Aug 21, 2021 5:50:47 GMT -7
I was going to post a separate thread but figured the info could be helpful here.
When the ECU is flashed, can you remove the exhaust valve and O2 sensors? If so, does an engine light come on or can that all be addressed with the flash?
Also, does the flash affect all 3 maps or the maps you want? Can you request to have the fan come on at a lower temp?
I saw a couple flash vids from a tuner in SC but it looks like he does more drag racing so I’m not sure if the tune would be more geared for peak power vs. smoothness. I was also told about vcyclenut but haven’t looked into him yet.
Post by hooli on Aug 23, 2021 18:32:36 GMT -7
1. Depends on if you're replacing the stock cat with an aftermarket link pipe. 2WDW also offers a flash that retains the cat and requires that you wire the Exup open. They claim some hp gains for this mod. 2. Yes. Flash address this. 3. All three maps. 4. Yes.
Hit up 2WDW (Two Wheel Dyno Works). They've flashed a shit-ton of FZ/MT-10's and are very customer-service oriented. Happy with the flash they did for my 2018.
redlinez
Post by redlinez on Aug 24, 2021 14:42:24 GMT -7
I used Chris Moore (Moore Mafia) out of Greenville SC.
Post by Deleted on Aug 25, 2021 7:22:08 GMT -7
I used Chris Moore (Moore Mafia) out of Greenville SC. I watch all of his videos! He seems like a great tuner that actually cares about getting the best tune on a bike. How do you like his tune?
mclovin
Post by mclovin on Aug 25, 2021 9:09:44 GMT -7
I was going to post a separate thread but figured the info could be helpful here. When the ECU is flashed, can you remove the exhaust valve and O2 sensors? If so, does an engine light come on or can that all be addressed with the flash? Also, does the flash affect all 3 maps or the maps you want? Can you request to have the fan come on at a lower temp? I saw a couple flash vids from a tuner in SC but it looks like he does more drag racing so I’m not sure if the tune would be more geared for peak power vs. smoothness. I was also told about vcyclenut but haven’t looked into him yet. Vcyclenut's flash allows you to remove the exup valve and the O2 sensors. no engine light. It affects all 3 maps. He automatically lowers the fan temp.
Check out his website which explains everything he does. Give him a call. He's totally customer service oriented. He even helped a customer do a comparison against Ivan's flash on another forum. I think he does so many that other tuners don't see enough of the same bikes to refine it as much as he has / does.
redlinez
Post by redlinez on Aug 26, 2021 13:14:40 GMT -7
I used Chris Moore (Moore Mafia) out of Greenville SC. I watch all of his videos! He seems like a great tuner that actually cares about getting the best tune on a bike. How do you like his tune? No complaints so far, I've only ridden once since the tune and it seemed to feel less snatchy. I also just had a friend set up my suspension for my 210 pound self, looking forward to another ride!
wingnut03
Post by wingnut03 on Aug 31, 2021 8:52:49 GMT -7
Hi,I did the flash with 2WDW, lowered fan temp,unplug oxygen sensor,wire open exhaust valve,this made my bike go from fast to just Crazy.Smoothed out throttle in all settings,really makes the quick shifter work really smooth,you can find videos on youtube or here to unplug oxy and wire open exhaust valve.Flashing the ecu is the best mod to this bike.
fzsea
Post by fzsea on Sept 1, 2021 9:15:07 GMT -7
I did Nels (2WD)stock flash as well. I think it's my 4th bike with them since '14, but I do live 15-30 minutes away, depending on traffic. I've enjoyed my fz09's, xsr and mt10 flashes. Everyone's going to have a different experience and it seems there are positive ecu techs out there that have done great work over the years. I don't think you can go wrong with one of the more established providers. It's funny how it all started with Nick (Stoltec) and my fz09 7 years ago this week. He partnered with Nels....good times.
krod877
Post by krod877 on Sept 9, 2021 19:51:23 GMT -7
I went With Moore Mafia Chris did an Amazing ECU tune and Quick Shifter Fix...
blueblur
Post by blueblur on Sept 20, 2021 17:57:28 GMT -7
Did anyone get a vcycle tune that wasn’t happy with the least aggressive mode? I need to get some more time in on it but I feel like I lost some smoothness, especially with the on/off throttle and lost the general approachable-ness of that mode.
