leland23
Post by leland23 on Aug 13, 2021 4:48:40 GMT -7
So the bike wants to start and sometimes it will but as soon as I let go of the start it dies, I can’t figure it out. The only thing that seems wrong is the fan relay, would that stop it from starting??
weehe
Post by weehe on Aug 13, 2021 10:32:12 GMT -7
So it actually starts then dies or just turns over until you stop trying to start it?
Post by RedAndBlack on Aug 13, 2021 12:14:59 GMT -7
Always start with the battery when it comes to electrical issues. Test the voltage or just buy a new one. If it works, great. If it doesn't, return the battery or just keep it as a spare for when you will need it.
oldguymadspeed
Post by oldguymadspeed on Aug 14, 2021 14:26:04 GMT -7
Mine does this. Hit the start button and it acts like it starts but doesn't. I charged the battery and it was good for awhile. Now it's acting up again. So it's probably the battery since my bike only gets ridden every few days or so and for short rides. Probably should just get a battery tender. Try charging your battery and see what happens.
Post by evitzee on Aug 15, 2021 7:13:00 GMT -7
All bikes should be on a Battery Tender if not ridden every day. Good practice.
Post by parthz8 on Aug 15, 2021 15:05:11 GMT -7
All bikes should be on a Battery Tender if not ridden every day. Good practice. Agree 100% both my R1M and MT-10s are always on my battery charger/maintainer Optimate-4 when parked in garage.
Post by willl84 on Aug 15, 2021 17:58:30 GMT -7
All bikes should be on a Battery Tender if not ridden every day. Good practice. Meh. I only put mine on the tender for winter storage.
leland23
Post by leland23 on Sept 16, 2021 9:01:01 GMT -7
Apologies everyone! I forgot to give an update. So it’s turns out I made a rookie mistake when installing my tip over sensor, yup, installed it upside down. Lesson learned.
I very much appreciate all the advice given!
Post by willl84 on Sept 17, 2021 19:37:23 GMT -7
Apologies everyone! I forgot to give an update. So it’s turns out I made a rookie mistake when installing my tip over sensor, yup, installed it upside down. Lesson learned. I very much appreciate all the advice given! Glad it was something simple!
