tryingtobebest
Post by tryingtobebest on Jul 25, 2021 9:13:48 GMT -7
Hi, i know and everybody says it everywhere on repetitive basis that the engine is from R1 but what about the transmission/gear ratios? Are they from R1 also or they are regeared for a street use?
terrys
Post by terrys on Jul 25, 2021 13:24:21 GMT -7
The R1 is identical except for the final drive which has a 41 tooth sprocket instead of 43 for taller gearing on the R1.
Post by willl84 on Jul 26, 2021 4:14:50 GMT -7
Definitely thinking of putting a 41T rear on honestly. 6k @ 80MPH is a bit harsh IMO
tryingtobebest
Post by tryingtobebest on Jul 26, 2021 11:13:00 GMT -7
terrys
Post by terrys on Jul 26, 2021 13:55:36 GMT -7
Yes the image is taken from the MT-10 service manual. The R1 table below is identical with the exception of the final driven sprocket size:
The link indicated a different primary reduction (crank to clutch basket) between the R1 and MT, which seems unlikely as that would require engineering changes to the crank and clutch which would be costly for Yamaha.
Post by willl84 on Jul 27, 2021 5:42:45 GMT -7
The link indicated a different primary reduction (crank to clutch basket) between the R1 and MT, which seems unlikely as that would require engineering changes to the crank and clutch which would be costly for Yamaha. I mean they went and changed a bunch of other stuff to drop 40HP from the R1 so it wouldn't be that far-fetched
rrman171
Post by rrman171 on Jul 28, 2021 22:20:55 GMT -7
The link says it is a 2012 R1.
Post by willl84 on Jul 29, 2021 4:04:57 GMT -7
The link says it is a 2012 R1. The service manual for the 2015-2019 R1 (where our engines come from) says the same
tryingtobebest
Post by tryingtobebest on Aug 3, 2021 23:14:54 GMT -7
Terrys, can you find similar spec for Mt10 and possibly post it here?
Post by willl84 on Aug 4, 2021 3:50:47 GMT -7
Terrys, can you find similar spec for Mt10 and possibly post it here? He did. The first pic he posted is the R1 (41/16 final drive). The second is the Mt-10 (43/16 final drive)
olivierzx
Post by olivierzx on Aug 5, 2021 9:45:25 GMT -7
Remember that if you change the secondary ratio the cruise control will not work anymore.
trini1
Post by trini1 on Aug 5, 2021 16:48:32 GMT -7
And why would the cruise not work?
Post by sdshawn on Aug 5, 2021 18:18:21 GMT -7
www.gearingcommander.com/ I recommend this site to everyone it has way more then you would want to know about gearing for tons of bikes and changes in ratios if you are thinking about it. Just type in your year make and model and it will give you the oem ratio from the factory then you can add 2 more changes and conpare theoretical or mathamatical let's say If on a Dino.
Post by willl84 on Aug 6, 2021 4:22:59 GMT -7
Remember that if you change the secondary ratio the cruise control will not work anymore. Sure it will. It uses the ABS speed sensors on the wheels. It'll work just fine.
Post by willl84 on Aug 6, 2021 4:25:45 GMT -7
www.gearingcommander.com/ I recommend this site to everyone it has way more then you would want to know about gearing for tons of bikes and changes in ratios if you are thinking about it. Just type in your year make and model and it will give you the oem ratio from the factory then you can add 2 more changes and conpare theoretical or mathamatical let's say If on a Dino. Holy shit that site is AWESOME. Thanks!
Post by sdshawn on Aug 9, 2021 5:53:16 GMT -7
I thought the same thing when it was shared with me. I hope it's helpful with possible gearing changes.
thejackgraves13
Post by thejackgraves13 on Sept 2, 2023 20:59:20 GMT -7
Just geared my MT10 16-41 and Love it
