addidassler
Post by addidassler on Jul 24, 2021 12:26:58 GMT -7
Hello riders, New owner of a 2021 model. Now I’m looking into front and rear stands. For my other bike, not a Yamaha, I use pitbull for the triple tree and a regular rear. Does someone has experience with complete pitbull? I was on their website but couldn’t find it! Thanks for any help.
Post by RedAndBlack on Jul 24, 2021 20:40:31 GMT -7
Welcome to the forum. It's the #36 pin for the front. Obviously the rear stand will work with 6 mm spools. I use pitbulls and don't have to adjust the rear stand between my two bikes.
Post by willl84 on Jul 25, 2021 3:40:20 GMT -7
I have a set of Pit Bull stands I've used for over 15 years now, just had to buy the pin to fit the MT stem. I also have the lifter adapters for the rear and machined my own lifter hooks for the swingarm. You need to be careful using the front stand if you use it to lift from the fork bottoms. The front wheel speed sensor is in the way. Pit Bull sells a lifter for that side with one short leg to clear the sensor
