mt10nick
Post by mt10nick on Jun 14, 2021 16:59:18 GMT -7
Hi all, I am new to the forums. I just picked up an MT10 about 2 months ago and have been loving it. It did not stay stock for long! I decided that some of my first mods were going to be to the levers. I got a cheap pack on amazon that I quickly learned would not cut it as the cruise control piece held it off since the lever was designed for an R1. I sucked it up and ordered a Pazzo racing lever for it, which was pretty pricey. Although this lever has the actual extension to push the cruise control sensor inwards, it does not actually push it in, making my cruise control work. I have tried tightening the clutch down but that doesn't fix the issue. What gives? As you can see in the photos, there is quite a large space between where the lever sits and where it makes contact with the handlebars. This is because the cruise control sensor is holding it out.
mt10nick
Post by mt10nick on Jun 14, 2021 18:05:57 GMT -7
I have solved my own problem - things needed a dash more lubricant, and then the nut and bolt that hold the lever into place were too tight. After doing these adjustments, the clutch is absolutely as smooth as butter.
