Post by parthz8 on May 14, 2021 15:49:30 GMT -7
Hello Members- I am again stuck with MT-10 displaying Coolant and Air temperature in ⁰F. (When i say again, means i have same display on my R1M 2015 model - ⁰F). For metric world this is unusual. There is no way i can change it to ⁰C thru any settings. Other models from Japan, New-Zealand, Australia shows ⁰C. When i went to dealer/Yamaha workshop (second time) they were clueless and of no help. Anyone knows how to change Coolant and Air temperature display to ⁰C? (Without doing self calculations of conversions) ECU Setting? Change the display? Whatever it takes....
Post by sdshawn on May 15, 2021 12:54:45 GMT -7
Wait it displays ambient temperature? I thought it was only coolant how do I change to air temp?
Post by parthz8 on May 15, 2021 14:09:58 GMT -7
Hi sdshawn- To change display between Coolant temperature and Air temperature, Keep "SELECT" Switch on clutch bar pushed for 2 seconds and display will change to either temperature (as shown below) . What is your display, ⁰F or ⁰C?
Post by evitzee on May 18, 2021 7:02:56 GMT -7
The owner's manual explains how to change from F to C.
Post by sdshawn on May 18, 2021 10:22:23 GMT -7
Heay cool thanks for that info mine is F I'm in the USA and I did not get the owners manual but did download it and have not thought about it until it was brought up.
Post by parthz8 on May 18, 2021 13:42:15 GMT -7
Hi evitzee-
User and Service manual both does not mention how to change Coolant and Air temperature display to ⁰C from ⁰F...
Thanks-
Post by clayton on May 18, 2021 15:18:19 GMT -7
I don’t think it can be done! Iv looked and couldn’t find anything on it! Only thing u can do is switch between air temp and coolant temp
Post by sdshawn on May 18, 2021 18:54:49 GMT -7
I tried that out today worked great is there any other tricks like that I should know about? I just figured that's how it is really did not think much more about it. My fz09 had it and I used all the time here in socal it gets really hot here.
Now as far as changing the Celsius to feirenhiet what model did you buy US or elsewhere? Theirs gotta be a way to change that I would think like mph to kph .
Post by sdshawn on May 19, 2021 18:34:06 GMT -7
I found a video on YouTube on the fz09 it might be the same changing kph to mph I have not tried it yet but the guy said. Turn key on make sure your in odo then turn key off Then turn key on while holding select button for 3 sec it changed it Not sure if it does the temp but give that a try. Again it's a YouTube for a 09 kph to mph.
vullnet
Post by vullnet on May 20, 2021 15:06:41 GMT -7
I found a video on YouTube on the fz09 it might be the same changing kph to mph I have not tried it yet but the guy said. Turn key on make sure your in odo then turn key off Then turn key on while holding select button for 3 sec it changed it Not sure if it does the temp but give that a try. Again it's a YouTube for a 09 kph to mph. Not sure if that does change that. I used that to change the shift indicator light and the brightness of the screen, dont remember seeing C or F, or commie units vs mph. Could be wrong though, might be worth a try.
Post by evitzee on May 20, 2021 19:36:51 GMT -7
Hi evitzee- User and Service manual both does not mention how to change Coolant and Air temperature display to ⁰C from ⁰F... Thanks- I know that if you push "Clock" and "Reset" buttons simultaneously it will change indicators from 'miles' to 'kms' and vice versa (page 1-15 of the April 2016 US service manual). I naively assumed this would change the temp indicators (F and C) as well, but I've never tried it to see if that happens. Would be odd if you could change to kilometer readouts but the temp was still stuck on F, but who knows what is programmed into the system.
Post by parthz8 on May 23, 2021 14:36:49 GMT -7
i tried pushing "Clock" and "Reset" buttons simultaneously, no luck...it wont change ⁰F to ⁰C...
Post by sdshawn on May 24, 2021 19:07:36 GMT -7
I called yamaha north America about the question a week ago have not heard back yet , ill stay on it you can see it has it on the black and white page of the owners manual in the post above now im in very curious on the answer .
I will not stop until I get the answer I'm crazy that way. Stay tuned...
Post by parthz8 on Jun 25, 2021 12:55:11 GMT -7
I called yamaha north America about the question a week ago have not heard back yet , ill stay on it you can see it has it on the black and white page of the owners manual in the post above now im in very curious on the answer . I will not stop until I get the answer I'm crazy that way. Stay tuned... Hi sdshawn- You heard anything from Yamaha North America? Yamaha Middle East folks are pretty useless
Post by sdshawn on Jun 28, 2021 18:09:42 GMT -7
Nothing
Post by sdshawn on Jun 29, 2021 8:44:26 GMT -7
I called again today sorry I kinda forgot about it but after a few techs answered back to the guy helping me they said no you can not change it as far as north America bikes. I know not much help but thats what he said .
Post by rracerfz10 on Jun 30, 2021 5:58:27 GMT -7
push and hold clock and reset with the key off. While still holding them turn the key on and keep holding the buttons and the settings will be able to be changed. This how you also change your shift light point and brightness and other things.
Post by parthz8 on Jun 30, 2021 15:16:53 GMT -7
push and hold clock and reset with the key off. While still holding them turn the key on and keep holding the buttons and the settings will be able to be changed. This how you also change your shift light point and brightness and other things. Does this change Coolant and Air temperature display to ⁰C from ⁰F?
Post by sdshawn on Jun 30, 2021 17:01:06 GMT -7
Try it and get back to us . That's some new info that that didn't know about abd aperantly either does yamaha Corp techs.
Post by rracerfz10 on Jul 6, 2021 5:21:43 GMT -7
Youtube is your friend lol
