Post by sdshawn on May 11, 2021 20:11:29 GMT -7
I looked out for that symtom this past weekends ride as well to a stall at a light . I have noticed a little clutch binding down where the cable housing seems to pinch when it funnels down by the frame where all the cables route. Its bothered me to a point where I bought a new cable luber motion pro.
I did try a change up the routing of it but have not found a better route for it then how it came so far. So just saying fallow the cables and see if they somehow Touch and change linkages even a fractions.
Also check your play in the throttle or twist it should aviously have some play mine has about a quarter of an inch that be right or not .
Just my thoughts after a few beers .
Post by willl84 on May 12, 2021 6:37:35 GMT -7
Throttle cable and clutch free play are perfect. It's clearly something to do with the electronic throttle and one of the two switches in the clutch perch.
Post by sdshawn on May 18, 2021 19:04:32 GMT -7
Ok so I tried it again today and it did go up one bar so slight I really did not notice before ,nothing changed going from neutral to first clutch in until I let clutch out halfway then pulled back in I noticed rpm went up then back down so slightly . I think you could take off with no gas at all in first that I did not try yet .
Post by willl84 on May 19, 2021 3:36:40 GMT -7
Ok so I tried it again today and it did go up one bar so slight I really did not notice before ,nothing changed going from neutral to first clutch in until I let clutch out halfway then pulled back in I noticed rpm went up then back down so slightly . I think you could take off with no gas at all in first that I did not try yet . No it's not enough to take off with,k it'll stall out lol
Post by willl84 on May 25, 2021 17:26:09 GMT -7
Ok so I emailed 2WDW and Nate emailed me back with this:
Strange that not everyone's bikes does this though...
Post by willl84 on Jun 5, 2021 4:25:33 GMT -7
So I emailed 2WDW about this a few weeks ago and they responded but I forgot to update this thread. This was the response from Nate:
So if it's normal then why don't other 2WDW-tuned bikes do this?
nakdgpa
Post by nakdgpa on Jun 5, 2021 7:37:35 GMT -7
So I emailed 2WDW about this a few weeks ago and they responded but I forgot to update this thread. This was the response from Nate: So if it's normal then why don't other 2WDW-tuned bikes do this? Thanks for the update. It is interesting that there isn’t more 2WDW tuned bikes doing this. I’d speculate the simple answer is your settings are different from other tunes.
superspirit
Post by superspirit on Jun 5, 2021 11:29:45 GMT -7
I have a 2wdw tune on mine and it does it also. I thought it was normal as most fuel injected vehicles do this, my 2019 mustang gt does it also, factory tune.
bigdadcoc
Post by bigdadcoc on Jun 11, 2021 22:12:58 GMT -7
Every time I let out the clutch my engine goes to redline until I stop shifting or hit thick traffic 🤣
