ridelyfe
Post by ridelyfe on Apr 15, 2021 16:58:08 GMT -7
So, I didn't have my tuner delete the PAIR system on the ECU because I didn't know i was going to need to remove it before I sent it off with the mods list.
I have plates and have sealed the airbox AIS connection but I need some advice on how to plug the solenoid or if I even need to? Thanks
Post by willl84 on Apr 16, 2021 4:46:26 GMT -7
ridelyfe
Post by ridelyfe on Apr 16, 2021 5:09:43 GMT -7
I was looking for that item and all I could find was their Exup valve servo healer. Oh well, I have a rider from AU shipping me out the resistor plug from the SmartMoto kit. Good dude.
I'll just zip tie the solenoid to the wiring harness and plug it in for now then. Thanks for respondong
Post by sdshawn on Apr 16, 2021 6:49:16 GMT -7
If your talking about the exup servo you can leave it plugged in with cables disconnected nothing more needed no code will activate. Assuming cat is removed if not wire exup valve open and if it's disconnected and you turn key on code will appear instantly and stay on until cleared just my 10 cents ..
Post by willl84 on Apr 16, 2021 6:50:54 GMT -7
If your talking about the exup servo you can leave it plugged in with cables disconnected nothing more needed no code will activate. Assuming cat is removed if not wire exup valve open and if it's disconnected and you turn key on code will appear instantly and stay on until cleared just my 10 cents .. Ho he's talking about the PAIR/AIS system
Post by sdshawn on Apr 16, 2021 7:47:21 GMT -7
Oh , insert foot to mouth.
ridelyfe
Post by ridelyfe on Apr 19, 2021 6:08:21 GMT -7
Oh , insert foot to mouth. No problem. Happens to me also. It is the AIS (pair system) solenoid plug. It requires an inline resistor or a sealing of the vacuum lines and reuse of the old plug. I ended up getting a resistor
