Post by willl84 on Mar 31, 2021 8:01:36 GMT -7
The fact that you changed the drain bolt and washer from OEM is probably where the hassle is coming from. "I changed this and now it's leaking" seems to me like a not-warranty thing honestly. But you mentioned it's leaking from somewhere other than the drain bolt so that should be warranty regardless of the different drain bolt. The leak at the drain bolt is most likely the washer that came with that bolt so I doubt they'll warranty that at all.
Also how is it easier to use a Phillips screwdriver for the drain bolt? Those are supposed to be pretty snug. If anything I would have replaced it with a standard hex head bolt.
Also Yamaha gives you a HUGE engine warranty if you do services with only their oil and filters but since you've used other oil that's out the window now. I did my first with the Yamalube, OEM drain gasket and filter. You have to upload a picture of the receipt as well as log the date and mileage it was done.
Post by clayton on Mar 31, 2021 8:45:27 GMT -7
Why would you want a philips head drain bolt? Philips head is the worst you can use! That’s why your bolts leaking, you can’t torque it down tight enough with a screwdriver! How did you even find a Phillips head drain bolt? I went with a magnetic hex head plug that uses a wrench/socket and use factory crush washers and never had any leaks on mine for 3 years and 12,000 miles
Post by mindcrime79 on Mar 31, 2021 9:12:36 GMT -7
So you altered the bike with shite parts and expect warranty service from an issue which was clearly a result of your shite parts? This must be the first vehicle you've ever purchased new?
Post by mindcrime79 on Mar 31, 2021 18:14:22 GMT -7
So you altered the bike with shite parts and expect warranty service from an issue which was clearly a result of your shite parts? This must be the first vehicle you've ever purchased new? Nice small brain comment . Isn't it funny how that works? You replaced a drain plug with a philips head screw and you are quick to point out someone else's intelligence. Someone with a small brain would say that after posting the question regarding the dilemna they created by having a small brain. Just admit I'm correct. You've never had a new vehicle warranty before. If you did you wouldn't be here asking this.
Post by rracerfz10 on Apr 1, 2021 5:23:27 GMT -7
Nice small brain comment . Isn't it funny how that works? You replaced a drain plug with a philips head screw and you are quick to point out someone else's intelligence. Someone with a small brain would say that after posting the question regarding the dilemna they created by having a small brain. Just admit I'm correct. You've never had a new vehicle warranty before. If you did you wouldn't be here asking this. Why is it every post I see of yours is you being a condescending dick? There's a place for that and it's called twitter. Go hang out there.
mvfjps
Retired from the UK now in South America.
Post by mvfjps on Apr 1, 2021 6:00:47 GMT -7
I thought that we were here to ask this type of question looing for guidance from those who may know more than us.
Sorry to say extremely bad form belittling a question posted on here... leaves a very bad taste in the mouth ,smacks of insecurity.
I have been riding, breaking putting bikes together for 45 years, now in my 61st year, and i am constantly learning... so for me all questions are valid and help the rest of us... if you have a question I am certain there will be others on here thinking the same and learning from things asked on this forum no matter what ... I am a new member here so if i am out of place posting the above i apologise but I felt it had to be said.
Long may there be questions of all kinds simple to the very complex..
Post by sdshawn on Apr 1, 2021 8:52:59 GMT -7
Hate to pile on but why would you change the bolt unless to a magnetic one Allen is way cleaner looking.
Plus the case leak where so I can check mine. I never lift bike from pan just saying front axle stand not to create a problem there.
You definitely gave the dealer a reason to deny you're claim
Post by rracerfz10 on Apr 1, 2021 12:13:06 GMT -7
I thought that we were here to ask this type of question looing for guidance from those who may know more than us. Sorry to say extremely bad form belittling a question posted on here... leaves a very bad taste in the mouth ,smacks of insecurity. I have been riding, breaking putting bikes together for 45 years, now in my 61st year, and i am constantly learning... so for me all questions are valid and help the rest of us... if you have a question I am certain there will be others on here thinking the same and learning from things asked on this forum no matter what ... I am a new member here so if i am out of place posting the above i apologise but I felt it had to be said. Long may there be questions of all kinds simple to the very complex.. You're all good man. Ask the questions you need to and just ignore the negative people.
bikeguyone
Post by bikeguyone on Apr 1, 2021 14:38:35 GMT -7
So just thinking. Clean the area around the drain plug and drain the oil into a new or very clean oil pan. Install the OEM drain plug and pour the oil back into the engine. Clean up any remaining leaks, drips or spills and check your oil level. Start the bike, check for leaks and ride around the block a couple of times. Park the bike and check to see if its still leaking. In my experience oil from a leaking drain plug will flow to other areas (when you ride) and can make it look like oil is leaking from another location.
Post by evitzee on Apr 1, 2021 17:29:18 GMT -7
There are two leaks, one from the gasket and one from the drain bolt. The gasket leak is a known one and is covered under warranty. A warranty claim cannot be denied because the owner did the job himself or used a different brand of oil, so the dealer is blowing smoke. Many have changed out the drain plug (usually Goldplug MP-02) with no leaks. The standard washer is a flat aluminum one although the old style crush washer is also acceptable. Since the plug has been changed the leak there will not be covered. Not sure why it is leaking unless the wrong size was selected. If you aren't using a Goldplug I'd suggest getting one.
Your dealer sounds like an asshat, you'll have to stand your ground and demand the pan gasket be replaced under warranty. Call Yamaha if he balks.
Post by RedAndBlack on Apr 1, 2021 20:05:54 GMT -7
Mod hat on: Just wanna tell everybody to chill out a bit. I like this forum as opposed to some others because we seem to be a very civil group of people and as a moderator for years now, we've only had a few issues. My advice is to just treat everybody like you're having an in person conversation. Ever if you're bigger and tougher than somebody, a lot of people won't start name calling across a table over such a discussion.
Ok back on topic: I've only dealt with Yamaha's customer service on a paperwork issue but I have dealt with other motorcycle companies and have found them very helpful with warranty issues. I would call Yamaha direct and explain the issue and FOCUS on the crankcase leak. This is a very well known issue and certainly entitles you to compensation under warranty. Replacing the drain plug with a non-OEM part that starts to leak, I could see Yamaha deciding not to cover that given the CRAP that is out there on ebay.
Another idea If you have the option, go to another dealer and don't even mention the drain plug. Just tell them the crankcase is leaking. Take it from there.
Post by mindcrime79 on Apr 1, 2021 21:23:41 GMT -7
Isn't it funny how that works? You replaced a drain plug with a philips head screw and you are quick to point out someone else's intelligence. Someone with a small brain would say that after posting the question regarding the dilemna they created by having a small brain. Just admit I'm correct. You've never had a new vehicle warranty before. If you did you wouldn't be here asking this. Why is it every post I see of yours is you being a condescending dick? There's a place for that and it's called twitter. Go hang out there. Racer, Please watch your language. I don't use this type of speech in a public, family- oriented forum. But since you've claimed the responsibility of making unsubstantiated accusations I'm going to have to ask you for specific references where I spoke in a condescending manner toward other members of this forum. Have I expressed negativity toward dealerships? Yes. Toward parts and equipment? Yes. I've not attacked anyone unprovoked. But aside from your heroic effort, the OP put non oem parts on a bike and it caused a leak. Hmm I'm no rocket scientist but..a reasonable person would say the cause was a bad part. OP then went and attacked my intelligence which he probably should have refrained from doing considering he posted a dilemna with a rather obvious cause and solution. After that I just defended myself from his poor response. Did you conveniently overlook your friends initial condescending remark? Your heroic ventures could be better placed. If you have a specific problem with me you can call me or message me privately instead of spreading false accusations in a public forum. Sounds like you're good at twitter yourself.
Post by mindcrime79 on Apr 1, 2021 21:28:13 GMT -7
I thought that we were here to ask this type of question looing for guidance from those who may know more than us. Sorry to say extremely bad form belittling a question posted on here... leaves a very bad taste in the mouth ,smacks of insecurity. I have been riding, breaking putting bikes together for 45 years, now in my 61st year, and i am constantly learning... so for me all questions are valid and help the rest of us... if you have a question I am certain there will be others on here thinking the same and learning from things asked on this forum no matter what ... I am a new member here so if i am out of place posting the above i apologise but I felt it had to be said. Long may there be questions of all kinds simple to the very complex.. You should definitely check your reading skills. I admittedly belittled a poor quality aftermarket drain plug. Not the person. OP went all 1st grade on us with the "you're stupid" comment.
goodman4
Post by goodman4 on Apr 1, 2021 23:31:22 GMT -7
You should definitely check your reading skills. I admittedly belittled a poor quality aftermarket drain plug. Not the person. OP went all 1st grade on us with the "you're stupid" comment. I thought the moderator did a good job telling everyone to mellow out on this. MindCrime, I'm sorry you felt you needed to pick back up the attacks in your post defending yourself twice that you don't attack people. I don't know any of you, but might like to some day. It's more productive to be civil and still make our point like several others did in this thread. To avoid escalation it is often better to avoid phrases like "you should definitely check your reading skills" and "this must be the first vehicle you've ever purchased new" These are belittling attacks as I read them. Just changing a couple words can still make the point and possibly even get people to understand us instead of getting defensive.
Post by sdshawn on Apr 2, 2021 19:39:41 GMT -7
I just went back and read every post on this thread and had no idea how or why it went off the rails in a way did. Just to let everyone know I don't think we should be judging anyone for anything at anytime choises good or bad I for one regret chiming when I did .
Just to let this forum know so I don't get corrected on my post here English and grammar never been my strong suite . I dig ditches for a living and very good at it so no judgment from me ever on how or why poeple do what they do.
The only thing I know is I love love my black beauty I think even my wife likes but hates her. Absolutely the most fun I've ever had on 2 wheels I'm 51 ridding since 5 that's what forum are about.
I can tell we have sone really smart poeple on this forum who love this machine let's not loose that.
