goodman4
Post by goodman4 on Mar 29, 2021 7:38:24 GMT -7
Splitting this off from an accessories thread - I need help on how to remove the Rear side cover (COVER, SIDE 2, Part #: B67-21721-00-P5) without breaking tabs. Anybody do this and have any advice?
Also if anyone has a pair of these sitting around in Ice-Fluo grey and would like to sell, please PM me.
terrys
Post by terrys on Mar 29, 2021 11:19:53 GMT -7
If these are the small covers under the seat, there are screws visible with the seat removed and a couple of push-pins on the underside from memory. After that they just slide off.
goodman4
Post by goodman4 on Mar 29, 2021 13:48:09 GMT -7
If these are the small covers under the seat, there are screws visible with the seat removed and a couple of push-pins on the underside from memory. After that they just slide off. Thanks! That helped a lot! I did have to remove the side panels to get to those screws, but it was straightforward after that. Seems simple now, but most things are simple once you know how. Still looking for a grey rear panel cover if someone has one lying around...
