fenianbastard
Post by fenianbastard on Jan 7, 2021 19:23:07 GMT -7
I took the rear wheel off for a new tire. The removed the caliper and the silver colored caliper holder. I am having a bitch of a time getting everything to fit back together. Is it one of those finesse issues or am I missing something. The owner's manual doesn't directly address this and I have searched here. Any help appreciated. Thanks
Post by dkim213 on Jan 7, 2021 19:32:23 GMT -7
Finesse issue
si
Post by si on Jan 7, 2021 19:42:10 GMT -7
Yep can be a B**** especially the spacer on the calliper side
Here is a link for you
vk
Post by vk on Jan 8, 2021 5:00:21 GMT -7
Haha oh yeah it's a pain. First time I took off the tire was a straight up headache. I had my wife holding the spacer on one side, daughter holding the other.
Once back on and aligned I went straight to STG and ordered the pitbull tire wedge deal. Expensive but worth every friggin cent...I had everyone pissed off.
Post by willl84 on Jan 8, 2021 7:06:57 GMT -7
Haha oh yeah it's a pain. First time I took off the tire was a straight up headache. I had my wife holding the spacer on one side, daughter holding the other. Once back on and aligned I went straight to STG and ordered the pitbull tire wedge deal. Expensive but worth every friggin cent...I had everyone pissed off. Just did the same with mine but I managed to do it all by myself. What a PITA! I'm definitely getting that pit bull helper - I've seen it around and was always like "meh" but now having done my rear and knowing how huge of a pain it is I'll be getting one lol
goodman4
Post by goodman4 on Jan 8, 2021 15:12:36 GMT -7
Thanks for posting that video. I'm going to attempt to cut a piece of wood to work like the pit bull helper and see how it goes. I'll spend the $90 if it doesn't behave like I think it will. I have never taken off a wheel myself but that's part of the reason I got the rear Pit Bull stand and was planning to get the front in the spring. How does removing and reinstalling the front compare to the rear? Is there anything tricky there?
Post by willl84 on Jan 8, 2021 18:18:07 GMT -7
Thanks for posting that video. I'm going to attempt to cut a piece of wood to work like the pit bull helper and see how it goes. I'll spend the $90 if it doesn't behave like I think it will. I have never taken off a wheel myself but that's part of the reason I got the rear Pit Bull stand and was planning to get the front in the spring. How does removing and reinstalling the front compare to the rear? Is there anything tricky there? Front is much easier. Calipers have to come off but that's only 2 bolts per caliper and the pads won't fall out like they do on the rear (if you remove the rear caliper from the bracket). If you get the Pit Bull front stand get the optional holder (https://www.sportbiketrackgear.com/pit-bull-front-stand-abs-friendly-hybrid-swivel/ - get the left side one) that's got one shorter pin that will clear the front wheel speed sensor. The standard pit bull holders will hit the sensor. I also have the hybrid stand so I just lift it from the bottom of the triple tree instead
fenianbastard
Post by fenianbastard on Jan 9, 2021 6:17:22 GMT -7
Thankyou Thankyou Thankyou. I was about to lose my mind, I thought I had lost a bolt that held the caliper hanger then realized there isn't one, it just sits there.
Post by hooli on Jan 10, 2021 0:43:13 GMT -7
I strongly suggest that you invest in a set of captive wheel spacers. They are held in place by the dust seals and will save you the headache of spacers popping out and rolling across the garage floor. Worth their weight in gold, they are.
fenianbastard
Post by fenianbastard on Jan 10, 2021 18:13:21 GMT -7
I got it replaced using some home made ingenuity based on the video. Thanks again to all.
thebeast
Post by thebeast on Jan 12, 2021 6:47:07 GMT -7
I use a ratchet strap thru the rear wheel and over the seat... easy and adjustable.
Post by rracerfz10 on Jan 22, 2021 6:26:25 GMT -7
Lightech chain adjusters FTW. makes 90% of all rear wheel stuff so much easier. Especially chain adjustments.
