Post by willl84 on Jan 28, 2021 15:18:56 GMT -7
Let’s fuuccckking goooo boiiiiis! Just went out and tried to start it and Bam! Bike started and idled! Thanks for all the support guys wouldn’t have been able to do it without the extra help! I agree with willl84 go back and triple check all the connecters for everything. Make sure your clutch switch is working and that your sidestand switch isn't all gunked up with chain lube. there are a dozen things that could cause this. But I also don't hear your fuel pump priming either. Try this,key off, bike in neutral, start/stop switch in the run position, turn the key on and you should hear the fuel pump kick on and it should be loud. He got it sorted. Cams were swapped 👍
Post by rracerfz10 on Jan 29, 2021 10:16:25 GMT -7
Oh well I guess I should've read the entire thread then lol. Glad it's fixed.
