mclovin
Post by mclovin on Dec 10, 2020 10:23:49 GMT -7
I searched the forum and didn't see much about this topic. How many miles are you guys getting out of chains and sprockets?
I'm also wondering about chain size. The stock chain is 525 but virtually every 525 aftermarket chain states that it's recommended for up to around 100 HP. I've done chains and sprockets on a lot of bikes but never saw a discrepancy like this before.
Post by dkim213 on Dec 10, 2020 11:33:04 GMT -7
I see them rated on displacement from DID, RK, EK. It looks dependent on chain model from each manufacturer.
I wouldn’t be concerned about if the factory 525 is enough. Just ride the bike.
Post by willl84 on Dec 11, 2020 8:57:04 GMT -7
Yea there's people doing 520 conversions for that extra 0.0002845HP so I wouldn't worry about it. I'm used to liter bikes coming with a beefy 530 chain that tends to last quite a while. But chain life is dependent on how you are about maintaining it - keep it loose and dry and it'll wear out fast. I usually check tension and clean/lube at least once a month. Cheap insurance and it makes them last a long time. I've always used the Bel-Ray Super Clean chain lube too. Works awesome with minimal fling-off
fjrchuck
Post by fjrchuck on Dec 11, 2020 11:09:17 GMT -7
I have 25,000 miles on my original chain and sprockets and they still look great. No tight links and the sprockets aren't really rounded yet. I was going to replace this winter, but may wait another (5K mile) year......
I use Chain wax and "lube" about every 4-500 miles. Minimal adjustment since the first couple of thousand miles. RUN IT!
mclovin
Post by mclovin on Dec 11, 2020 22:23:30 GMT -7
Yea there's people doing 520 conversions for that extra 0.0002845HP so I wouldn't worry about it. I'm used to liter bikes coming with a beefy 530 chain that tends to last quite a while. But chain life is dependent on how you are about maintaining it - keep it loose and dry and it'll wear out fast. I usually check tension and clean/lube at least once a month. Cheap insurance and it makes them last a long time. I've always used the Bel-Ray Super Clean chain lube too. Works awesome with minimal fling-off I wasn't looking to change to a different size as much as trying to understand why aftermarket chains are all based on CC and HP and all of them are saying 525 is not rated for the HP of the MT 10. Yamaha parts diagram clearly shows 525 so that's what I'm going to use. I've always done my own work and I like to understand how stuff works.
Post by willl84 on Dec 14, 2020 8:24:31 GMT -7
Yea there's people doing 520 conversions for that extra 0.0002845HP so I wouldn't worry about it. I'm used to liter bikes coming with a beefy 530 chain that tends to last quite a while. But chain life is dependent on how you are about maintaining it - keep it loose and dry and it'll wear out fast. I usually check tension and clean/lube at least once a month. Cheap insurance and it makes them last a long time. I've always used the Bel-Ray Super Clean chain lube too. Works awesome with minimal fling-off I wasn't looking to change to a different size as much as trying to understand why aftermarket chains are all based on CC and HP and all of them are saying 525 is not rated for the HP of the MT 10. Yamaha parts diagram clearly shows 525 so that's what I'm going to use. I've always done my own work and I like to understand how stuff works. Oh for sure I understand what you're getting at. I'm surprised as well that it came with a 525 instead of a 530. My theory with these kinda thing is if it came like that from the factory it's gotta be fine.
