is
Post by is on Nov 28, 2020 17:48:33 GMT -7
Hi guys! I have seen a small oil leak from the straight plug of the rocker arm shaft on the right side of my 2020 Mt10. Did this happen to any of you? If so how did you fix it? Any thoughts are really appreciated!
jdm74
Post by jdm74 on Nov 29, 2020 5:13:18 GMT -7
A 2020 should still be under warranty unless you bought it used. If you bought it new it should be warranty work.
maximus
Post by maximus on Nov 29, 2020 8:39:54 GMT -7
Any pictures? I haven’t had that, but I’ve had 2 small oil leaks on my 2020 that I was lucky enough to fix myself, for now anyway, by simply replacing the o rings. Bike is under 1k miles. I suspect yours might be more involved, I agree w utilizing your warranty.
is
Post by is on Dec 1, 2020 19:20:50 GMT -7
Thank you for the responses! Here is the image with the oil leak and circled in red, on the engine image from the service manual, is where it's happening. I hope it's not a major thing! And yes, the bike is still under warranty.
Post by hooli on Dec 1, 2020 19:54:37 GMT -7
Did you try and tighten it?
is
Post by is on Dec 2, 2020 11:33:01 GMT -7
There is hardly any space for an allen key, the frame is right in front of it... so i couldn't try to tighten it.
I wiped it and went for a ride and when I came back there was no leak. I'm assuming it does it when the engine gets really hot.
dgrey
Post by dgrey on Dec 9, 2020 21:33:55 GMT -7
hi did you solved this issue? i have the same problem with my yamaha mt10 2020 with 3000km im from chile.
