gadget
Post by gadget on Aug 15, 2020 23:34:26 GMT -7
Hi all, hope this is the place to post this question ..Mods ...please move it if it's not. Hoping someone can help with this ... my 2016 MT10 special build has a FH022BA reg/rec but no wiring with it yet, I'm doing a custom build so all wiring is very minimal compared to oem. So ... the FH022BA rectifier is a 5 wire SINGLE plug, as you look at the plug head on .. which of the two top terminals is the positive /charging terminal? I know the bottom three are the stator wires. Hope someone can help with this, don't want fires before its built 🤣 thanks.
Post by willl84 on Aug 26, 2020 11:09:21 GMT -7
What colors do you have for those two pins? One should be ground so you should be able to use a multimeter and check resistance from each of those pins to the body of the rectifier if it's grounded through the body.
