hobbit0808
Post by hobbit0808 on Jul 25, 2020 3:12:04 GMT -7
Hi there, is a decat system the way forward on a mt10? Not sure just to go with a slip on,or just decat it? And do you always have to re map ecu? Cheers
Mt10 decat
Jul 27, 2020 22:26:57 GMT -7
via mobile
Post by rracerfz10 on Jul 27, 2020 22:26:57 GMT -7
If you decat yes you’ll need a tune but not with a slip-on.
fztenn
Post by fztenn on Jul 29, 2020 6:27:49 GMT -7
I was on the fence for the longest in regards to a decat and tune, then I finally went for it...I can honestly say that it was the best mod I've done to date! It takes your bike to the "next level". I rode decatted briefly without the tune at first, but now I see how both steps work in conjunction to make the investment well worth the expense. To stop short of both mods you are only cheating yourself out of the full experience! IMO, this should have been the first money spent. I'm pretty sure others feel the same way.
wingnut03
Post by wingnut03 on Jul 31, 2020 9:28:15 GMT -7
Hi,the best money you can spend on this bike is flashing the ECU,but you will have to decide slip-on or de-cat first.I have had a 2017 and a 2020,both bikes just a slip-on with a flash,hope thi helps.Welcome to the forume
Post by mindcrime79 on Aug 2, 2020 0:16:18 GMT -7
Decat is cheap and simple on the fz/my. Honda's make it difficult and expensive for some reason.
