erriikk
Post by erriikk on Jun 23, 2020 11:17:15 GMT -7
Hello! I would like to paint some parts on my blue 2017 model. Basically painting all silver parts black. The rear silver part is easy, front upper easy.... The tricky one seems to be the lower front fairing. Does someone have pictures or can help me how to remove that one?
Post by RedAndBlack on Jun 23, 2020 17:07:41 GMT -7
Have you checked out the service manual? Should include a fairly useful explanation if you can find it. I've never messed with it so unfortunately I don't know.
erriikk
Post by erriikk on Jun 27, 2020 2:35:54 GMT -7
Thanks! I can check it out. Should be easy to find on the interballz somewhere I guess
ahmad0420
Post by ahmad0420 on Jun 30, 2020 10:57:20 GMT -7
Hello! I would like to paint some parts on my blue 2017 model. Basically painting all silver parts black. The rear silver part is easy, front upper easy.... The tricky one seems to be the lower front fairing. Does someone have pictures or can help me how to remove that one? I had to remove the whole headlight to access the one single screw that dislodge that small fairing thingy.
rdowdall
Post by rdowdall on Mar 11, 2021 16:36:07 GMT -7
Can you tell me how you removed the headlight assembly. I've got all the plastic off except the headlight cowling.
Post by willl84 on Mar 11, 2021 16:57:38 GMT -7
Can you tell me how you removed the headlight assembly. I've got all the plastic off except the headlight cowling. It's a freaking nightmare honestly. I took mine apart to get the little chin spoiler wrapped. Here's the exploded view: www.partzilla.com/catalog/yamaha/motorcycle/2019/mt10-mt10kb/cowling-1You need to remove the four Phillips screws (#4) that hold the headlight to the bracket. Then once that's off you need to remove the two Phillips screws That go through from the backside of the headlight assembly and hold the cowling on. Then once that's off you need to remove the two screws (#20) to remove the chin spoiler from the headlight assembly.
