rhino
Post by rhino on Jun 15, 2020 13:38:32 GMT -7
I'd like to do the same thing for my 10 but I can't seem to find any information on the relay. Do we have a PNP solution to stop LED lighting from going ballistic? I already have the Protons on the 10 so another signal brand isn't really on the table. If we don't have a PNP relay what solutions have you guys used?
This has been surprisingly tricky to find consistent info on. I'm reading everything from there is no replaceable relay, to yes we have a two-pin relay, and yes we have a 3-pin relay.
denis998
Post by denis998 on Aug 27, 2020 13:27:19 GMT -7
Hi There is no phisical flasher relay on FZ-10 / MT-10
The flasher are directly controlled by and connected to the meter assembly (speedo/RPM/... cluster)
Post by willl84 on Aug 31, 2020 11:50:11 GMT -7
Just like cars these days - everything is connected to the BCM. In my old Silverado I did a relay swap for LED's. Can't in my Cruze - have to use resistors 🤦♂️
