fishforfun2
Post by fishforfun2 on Aug 11, 2020 9:48:27 GMT -7
Sorry to hear about eng fail. I have a motor with 15K miles that was running great til I went off the road. I ran the motor and its fine after crash and is for sale on parts board if you are looking for one. I removed it from frame a couple days ago.
ceebietje13
Post by ceebietje13 on Aug 19, 2020 8:35:11 GMT -7
Better put him back to stock , also the exhaust . If you tell them you put something aftermarket on it you lose you're warranty .
Post by evitzee on Aug 20, 2020 13:33:51 GMT -7
I know on cars they can tell if the ECU has been flashed even if it is put back to stock, it has a memory function. Don't know if the MT-10 does this or not. It is hard to fool Yamaha, they aren't going to do all kinds of repairs under warranty if it appears the bike has been retuned.
ballmead
Post by ballmead on Aug 28, 2020 14:16:38 GMT -7
If it was flashed with Woolwich gear and then flashed back to stock, they shouldn't be able to detect any changes.
maximus
Post by maximus on Oct 2, 2020 16:02:49 GMT -7
If it was flashed with Woolwich gear and then flashed back to stock, they shouldn't be able to detect any changes. Is this same, flashing back to stock, able to be accomplished when using FT?
harry76
Post by harry76 on Oct 4, 2020 10:53:40 GMT -7
Did we ever get an update on what happened?
kratosfz10
Post by kratosfz10 on Oct 7, 2020 8:39:39 GMT -7
Anyone seen this? motorandwheels.com/common-problems-yamaha-mt-10/Their number 2 sign your engine has blown "Blown rods and pistons are also a sign that your engine has failed" Whether there is any truth to this article, who knows, but I found that funny.
rman
Post by rman on Jun 14, 2022 21:51:37 GMT -7
So did they cover it?
skratkat
Post by skratkat on Aug 4, 2022 23:43:35 GMT -7
Sometimes they just take a shit. You're not the first one but I know that won't make you feel better. A tune remember just alters the fuel map and turns off all the environmental stuff. None of that is going to make the engine fail, if anything it actually improves it's life by making it run cooler. That's because the bikes run really lean out the factory so in turn corrects the fuelling increasing the AF ratio inturn making it burn cooler. Leave it with Yamaha and maybe keep quiet about the ECU flash. Keep us posted though. True. The bike was running better after the tune I guess it was just a coincident. Will keep you posted what did yamaha say? or did you find out what might've caused the failure?
Post by hooli on Aug 6, 2022 21:20:00 GMT -7
Anyone seen this? motorandwheels.com/common-problems-yamaha-mt-10/Their number 2 sign your engine has blown "Blown rods and pistons are also a sign that your engine has failed" Whether there is any truth to this article, who knows, but I found that funny. Who the hell wrote this crap?
