thebeast
Post by thebeast on Apr 10, 2020 11:19:17 GMT -7
Any of you guys knows what those plastic tubes are for ? Will I have an issue with my new flashers if I do not have those still ? Thanks for your help.
superspirit
Post by superspirit on Apr 10, 2020 11:46:34 GMT -7
There has been a lot of speculation as to what those are. I can tell you this I removed them when I installed new turn signals on mine and they work flawlessly.
thebeast
Post by thebeast on Apr 10, 2020 12:22:33 GMT -7
Ok thanks, I guess it's part of JAPAN great mysteries !!!
Post by Deleted on Apr 10, 2020 15:52:00 GMT -7
They must be resistors, to prevent hyper-flashing. They're typically needed with LEDs, although nowadays they're incorporated into the relay.
Post by mindcrime79 on Apr 10, 2020 20:58:50 GMT -7
I ran into the same dilemma. I kept them on when I replaced my blinkers and it actually messed up the blinking speed. So long story short it is a resistor that is most likely not needed.
mattemike
Post by mattemike on Apr 11, 2020 4:53:04 GMT -7
Take them off if you'd like & get yourself a flasher relay designed for LED's. Did that on my previous FJ-09 when I went to LED sigs, As I recall TST Industries was my source.
superspirit
Post by superspirit on Apr 11, 2020 7:38:08 GMT -7
Fz10 already has led turn signals, no need to change flasher. I replaced my or turn signals with aftermarket led signals and they work just like factory
Post by RedAndBlack on Apr 12, 2020 20:38:37 GMT -7
They must be resistors, to prevent hyper-flashing. They're typically needed with LEDs, although nowadays they're incorporated into the relay. +1 on this. Although they are pretty long, I think this is most likely what they are.
