hypernaked
Post by hypernaked on Apr 8, 2020 17:40:08 GMT -7
Please see the video. Thanks!
Bike would not start one day. Got a jump and it fired up. A couple days later same no start issue.
chasx
Post by chasx on Apr 8, 2020 18:11:14 GMT -7
I can hear your fuel pump running and the cranking seems OK (maybe a bit slow). If a jump got you up and running the first thing I'd do is get a new battery.
vk
Post by vk on Apr 8, 2020 18:48:35 GMT -7
Got to agree with above. New battery time! Been down that road before and that sounds like a weak battery bro.
hypernaked
Post by hypernaked on Apr 8, 2020 20:05:58 GMT -7
I bought a new battery at the shop. I was thinking new battery as well since the bike is about to go on 4 yrs. I brought in my old battery and they said it was good. I bought the new battery anyways. After blowing and replacing my main fuse (whoops...but thank you Yamaha for the circuit protection), the bike is back to it's old non-starting self. Why would the old battery test as good for all the tests they ran on it...but it's unable to start the bike. Also...with the new battery...there should be no reason for it not to fire up the engine ...but it's not. I agree...it feels like a new battery is needed, but the bike is not starting even with the new battery and likewise with the old battery ..which supposedly checked out to be good. She's still under warranty...guess I could have her towed in......I am thinking of getting a new bike....wonder how much she's worth...could another fuse be blown? I was trying to get to the fuse box on the left faux air vent...not sure how to take it off after removing the two screws and the push pin...
wodger63
Post by wodger63 on Apr 8, 2020 20:51:04 GMT -7
I was trying to get to the fuse box on the left faux air vent...not sure how to take it off after removing the two screws and the push pin... Instructions are in your owners manual, chapter 7 page 31.
Post by evitzee on Apr 8, 2020 21:15:29 GMT -7
Stop. How did you blow your main fuse??? Reversed polarity on the battery? Main fuses don't blow without a good reason. That's a whole different issue than just a bad battery.
hypernaked
Post by hypernaked on Apr 8, 2020 21:33:27 GMT -7
Main fuse blew due to reverse polarity when switching out old battery with new. Fuse saved the bike's electrical. New fuse now in. Old problem prior to replacing the battery still persists. The engine turns a couple times or eventually not at all. Display lights up...no dimming. Before changing the battery there was a wicked clicking sound that would eventually follow repeated pressing of the ignition button. I thought that was the old battery going out and the magnets in the starter telling me that a new battery was needed.
3lseeker
Post by 3lseeker on Apr 9, 2020 11:36:07 GMT -7
Did you put a good charge on the new battery?
hypernaked
Post by hypernaked on Apr 9, 2020 13:44:49 GMT -7
I'll have to follow up with that 3lseeker. I took both the old and new battery in just 30 mins ago. I'm waiting for a call back to pick them up fully charged.
Post by Deleted on Apr 9, 2020 16:56:16 GMT -7
Hey Hypernaked, I wouldn't worry about your battery. Sounds exactly like mine, and I just replaced the battery with an OEM... and fully charged it before installing it. I replaced it because also thought the battery was weak, but the new one only cranks a hair better, so that's just the way these bikes are. Having said that, the starter seems to pause a little bit, then keep cranking, in a kind of cycle. My bike hasn't cranked up that long yet, but glad to know the starter behaves that way.
Finally, your bike definitely has an issue, but the hard part is diagnosing it. The first thing to check is ALL fuses, and any DTCs. Do you own a code reader and adapter? If not, I'd start there. With these electronic machines, you have to. I had trouble with mine early on, but it turned out to be a tight EXUP cable, which I promptly fixed after getting the adapter and code reader. And yes, it's possible you might have damaged the ECU with the reverse polarity, or some other electronic component, but hopefully not. Good luck.
hypernaked
Post by hypernaked on Apr 9, 2020 18:38:08 GMT -7
I just got the batteries back a couple hours ago. Both were in "bad" health according to the Honda battery tester they used at this other dealership. The charge on them was "good". Instead of buying a new battery from this dealership, I'm requesting a replacement battery from the dealership I bought the new battery from first. If things still don't fire up I'll check that I wasn't given a dud again...and then fix/repair accordingly. A pain...but fortunately I have another vehicle to get around until this is resolved.
Post by mindcrime79 on Apr 10, 2020 4:24:18 GMT -7
you check the basics? are spark plugs good? is fuel good? air filter good? could it be rectifier/regulator related?
hypernaked
Post by hypernaked on Apr 10, 2020 9:39:46 GMT -7
Thanks for the input all! Hopefully it's a quick fix. TBD...
hypernaked
Post by hypernaked on Apr 17, 2020 20:02:46 GMT -7
Post by Deleted on Jun 25, 2020 2:29:06 GMT -7
I just want to say thank you!!
I did the exact same thing a couple of days ago. My 2005 R1 was dead, so used the battery from the MT10. But the positioning of the battery is back to front and I wasn’t paying attention when I was putting it back in the MT, so reattached the battery incorrectly. Thought it was the lithium battery, bought a compatible charger and charged it up, realised main fuse was blown, replaced, it had the same issue as you. Came across this article and the instructions and photos you posted really helped me out. I had one 7.5a fuse blown for the Electronic Throttle Valve fuse. Replaced that and the bike started!!
So a BIG THANK YOU!!!!
I took it for a spin and the engine light is on, so guess I’ll get a code reader and see if I can clear it.
Post by RedAndBlack on Jun 28, 2020 15:19:42 GMT -7
FIXED!!! So I got her starting again. It was NOT the battery, since I'm using the OLD battery and she fired right back up. I had blown the main fuse due to reverse polarity with a new battery. WHOOPS. I honestly don't know why she didn't fire up and I had to get her towed a week back...but I did kind of leave her in the rain a couple nights. But I've ridden her in heavy rain with no issues before, during or after. Anyhow I did not check the other fuses. WHOOPS. Replaced the main fuse. Everything lit up but the bike engine would only crank, but not fire up and hold idle. Finally removed the air scoop today to check the rest of the fuses. I would have done these earlier, but I worked 4 straight 12hour shifts...so that wasn't happening. Long story short, finally popped the airscoop off after trying to figure it out over the last couple days. There are "invisible" fasteners you have to remove, thus I'm attaching a how to. Low and behold, I found TWO other fuses had blown!! I replaced them with the spares. BIKE fired up!!! It did have an engine code about the throttle positioning not matching up but I took it for a test run and there's no difference in the throttle than when I rode it in the past. I had a fake out engine code in the past as well. Erased them and rode. No issues since! I'm attaching some photos that I hope help in removing the air scoop. Maybe I should have a separate thread...because no one shows it in good enough detail ...that I've seen ...not even the mechanics manual.
This is an excellent How To. You should repost it in the Tech Tips section if you didn't already.
p3rcyp
Post by p3rcyp on Jul 10, 2020 7:04:26 GMT -7
Just wanted to post to say thanks to the opening poster. I did the old put the battery in wrong and it blew my 50A fuse. Replaced that got Crank but no start and started looking on the forums. If I followed all the other advice on different forums my bike would be in bits now and probably never go back together again :-)
The addition of the guide and pics was very welcomes so thank you again you just saved me so much time and effort. Bike working.
kratumay
Post by kratumay on Apr 14, 2021 13:52:48 GMT -7
Thanks all,
Funny how more experienced people than I fell for the same thing.
It's lead me to another question, I changed the fuses and waiting to get the OBD2 scanner and it's connecting port!
However, I can't get in to the bikes menu screen. I have the MT10SP so I can't change any riding modes.
The bikes rides ok, sometimes I wonder much better than before she doesn't get as hot either, might be the weather change but hey it's better all the same.
did anyone have the same / similar issues ?
I have the heated grips and they seem to have stopped working too, might be there individual fuses but thought I would ask.
nmwbt
Post by nmwbt on Feb 10, 2022 17:28:42 GMT -7
🙋🏻♂️I did it too!😡 I have installed 1,836 batteries in my life and have never installed one backwards…until today! Blew the main fuse and one 7.5 amp fuse! Stupid!!🙄
ewan
Post by ewan on Oct 5, 2023 12:58:56 GMT -7
Hello boys a little help needed , so just replaced my battery, I put it on the wrong way around as I was talking and not focusing , anyway blew the 50 amp block fuse the main one I think , iv replaced that but now when I turn it on I can’t hear the fuel pump kicking in ? Like u normaly hear the noise for around 3/4 seconds , and it’s just turning over not starting … any help !! Going out my mind
