cp4
Post by cp4 on Mar 26, 2020 18:28:03 GMT -7
Hello,
I’ve recently installed the yoshi 3/4 system on my mt 10. No matter what I do, I can feel slight leaks where the headers connect and at the muffler mid pipe connection. I’m not a fan of how much of a gap there is around the mid pipe header connection even with the stock exhaust gaskets used as the instructions indicate. Has anyone run into these issues? And moreover, will a slight leak cause any detriment or power loss?
Post by RedAndBlack on Mar 26, 2020 18:49:40 GMT -7
Welcome to the forum!! Did you use type of sealant??? You should use a high temperature sealant for the connections of the pipes. Leaks are expected due to the expansion and contraction of metal as it heats up. But sealant should help stop the leaks.
