Post by mindcrime79 on Jan 17, 2020 14:26:48 GMT -7
Hey guys anyone know what size bolts are utilized for the Sato Racing Hooks? Trying to find a black version as opposed to the chrome ones they provide.
Thank you.
gunnar
fabbin stuff...
Post by gunnar on Jan 17, 2020 14:45:40 GMT -7
M8X20 Pic of stock passenger peg bolt:
vstate60
Post by vstate60 on Jan 17, 2020 19:47:35 GMT -7
Hey guys anyone know what size bolts are utilized for the Sato Racing Hooks? Trying to find a black version as opposed to the chrome ones they provide. Thank you. What’re racing hooks? I ordered some MT-10 branded ‘covers’ for the passenger peg holes after I removed them and while the bolts stayed—the actual fancy cover fell off on both sides in one ride. Took a month to come from China....figured it’d take me less than that to destroy it.
vstate60
Post by vstate60 on Jan 17, 2020 19:51:44 GMT -7
M8X20 Pic of stock passenger peg bolt: Jesus Heavens just figured out what it is—for $90??! gunnar can you fab me up a simple carbon solution that I’ll never use to tie down my bike—just to bolt over the blank space created by removing the passenger pegs? You are the Carbon God around here....
Post by mindcrime79 on Jan 17, 2020 20:44:07 GMT -7
thanks. i thought i read on here that the stock bolts dont work for the sato hooks. will try..
gunnar
fabbin stuff...
Post by gunnar on Jan 17, 2020 21:03:21 GMT -7
thanks. i thought i read on here that the stock bolts dont work for the sato hooks. will try.. You are right. You need a regular hex socket cap screw, same diameter and length should work, but black oxide ones will rust eventually: I'll get back to you vstate. I opted for the cheap solution, went to AutoZone:
vstate60
Post by vstate60 on Jan 17, 2020 21:52:44 GMT -7
thanks. i thought i read on here that the stock bolts dont work for the sato hooks. will try.. You are right. You need a regular hex socket cap screw, same diameter and length should work, but black oxide ones will rust eventually: I'll get back to you vstate. I opted for the cheap solution, went to AutoZone: I’m down with whatever you create—will send $$ ahead!
Post by Deleted on Jan 20, 2020 15:25:19 GMT -7
I went from Evotech blanking plates, to the black Sato racing hooks, since I needed to tie down the bike to my truck at that location. And they worked perfectly. The Evotech plates look flimsy for strapping the bike, since they're thinner in the middle. Strictly an aesthetic item IMO, but they use the stock bolts. And they're relatively cheap at around $50 shipped.
gunnar
fabbin stuff...
Post by gunnar on Jan 20, 2020 16:37:11 GMT -7
Those Sato hooks are a joke...why would a company drill holes at the most critical weight bearing part of the triangle? I'm an amateur and I could come up with something that would hold 3 times the weight of the entire bike and still look decent.
vstate60
Post by vstate60 on Jan 20, 2020 17:12:01 GMT -7
Those Sato hooks are a joke...why would a company drill holes at the most critical weight bearing part of the triangle? I'm an amateur and I could come up with something that would hold 3 times the weight of the entire bike and still look decent. And for $90? Get real...I’m out.
gunnar
fabbin stuff...
Post by gunnar on Jan 20, 2020 17:14:30 GMT -7
3/16" carbon for vstate60, one of a kind, never to be duplicated:
vstate60
Post by vstate60 on Jan 20, 2020 18:38:44 GMT -7
3/16" carbon for vstate60, one of a kind, never to be duplicated: Pure sex— you’re my hero.
vstate60
Post by vstate60 on Jan 24, 2020 21:00:04 GMT -7
vstate60
Post by vstate60 on Jan 24, 2020 21:00:17 GMT -7
