fzryder
Post by fzryder on Jan 11, 2020 15:21:01 GMT -7
High I own a fz10 with 9500 miles and third gear is slipping pretty bad. Engine revs high but speed is delayed to engine. Has anyone changed their clutch on this bike and does anyone know of a set of high performance clutch plates available for this bike? Any help would be appreciated. Thanks
Post by Deleted on Jan 12, 2020 15:59:52 GMT -7
Did you buy the bike new? This is the first time I read of clutch problems, especially that early. Seems to me that it was abused, either willingly or unwillingly. Having said that, it could also be an oil issue, but I assume you have the correct Jaso2 in there, and also change it regularly, correct? And the cable is adjusted properly, with the appropriate free play, correct? If you answered yes to all, then it's definitely worn out. I have no suggestions for a new clutch, so will leave that to others. Good luck.
