auzzielee
Post by auzzielee on Dec 12, 2019 15:24:37 GMT -7
I'm planning on doing an engine swap to an R1 engine next winter in my 2017 FZ-10. To my understanding, I also need the wiring harness and ECU, as well as some of the accessories, like the quick shifter. No problem since I'm buying a salvage title R1 for all its parts.
My question is: is there some way to retain both the extra features of the R1 dash and my FZ cruise control? Can I use an MT10SP dash and hand controls? If not, I am open to suggestions.
Thanks in advance
Post by RedAndBlack on Dec 12, 2019 19:44:01 GMT -7
I have no idea about such a swap but remember that the MT and the R1 have two different powerbands and two different RPM ranges. So using an MT10SP speedo is going to have you redlining when you're only at peak RPM for the R1 engine
