david
Post by david on Dec 3, 2019 7:38:50 GMT -7
I had the dealer install the factory heated grips prior to picking up my MT10. Yesterday, fortunately while moving the bike in the garage, I heard a pop and the throttle side grip was completely loose. Looks like the plastic potion on the heater just gets glued to the plastic throttle. I was just going to glue it with some super glue, any thoughts / considerations? It would be a shame if this broke free on the road.
Thanks, David
Post by RedAndBlack on Dec 3, 2019 8:22:12 GMT -7
Maybe check with dealer and see if the parts are under warranty?
david
Post by david on Dec 3, 2019 9:39:06 GMT -7
Just went by Dealer. They say they use proTaper grip glue, evidently didn’t use enough. I’ll try that & use a lot.
chesterburnet
Post by chesterburnet on Jan 5, 2020 10:10:31 GMT -7
I used grip glue 4 bikes ago and it never worked. I ended up doing friction tale with gasoline poured on it and then slipping grip on like I used to do with old motocross bikes and it worked great. Last year I did heated grips on my FJ09 so I tried hairspray as a lot of people suggest. It worked great. I just did heated grips on MT10 a few weeks ago and used hairspray again and it worked great again. Grips don't budge. I used one of the old brands I remember being around when I was a kid because I guessed that the were less new age socially responsible chemicals in it. God bless fluorocarbons.
