dertymt
Post by dertymt on Nov 10, 2019 1:06:44 GMT -7
Hey guys I just replaced my own clutch pads and after putting everything back together I have no clutch at the lever. I did what the service manual said and made sure the teeth on the pull rod were facing backwards when I put the clutch cover back on but I have no clutch now. I'm afraid to start the bike. The pull rod was loose in the clutch, not sure if that's what it's meant to do, flop around that is. Is there a trick to getting it to bite the teeth in the clutch cover?
