yokohamafresh
Post by yokohamafresh on Oct 8, 2019 19:46:06 GMT -7
I currently have 13k miles on my FZ10 with no problems at all. Still in love.
bigkurka
Post by bigkurka on Oct 8, 2019 21:35:57 GMT -7
I got 4500 mile on my 2018 mt10. Had it for 1 year now. Only problem I've had was I picked up a nail in the rear tire.
fjrchuck
Post by fjrchuck on Oct 9, 2019 0:32:38 GMT -7
Just about to turn over 20,000 miles on my '17! Still loving it every time I ride it, especially the sound thru the full Akropovic exhaust I put on it!
ducagolf
Post by ducagolf on Oct 9, 2019 8:21:00 GMT -7
I have 17500 miles , only needed led headlight replaced(cracked lens) YES warranty. Changed spark plugs my self at 10000 miles. Always shifted a little clunky at times, but no oil burning, (usually change at 2500 to 3000 miles ). Very good ,reliable , and mega fun motorcycle.
theculturalattache
Post by theculturalattache on Oct 9, 2019 10:31:19 GMT -7
5000 on my 2018 model.
So far so good...
Post by Deleted on Oct 9, 2019 11:56:12 GMT -7
2,919 miles on my 2017 1-yr anniversary. Cancer battle didn't allow me to put more, but put an extra 1,010 miles on a borrowed bike at the Dragon, so in reality rode almost 4K miles this year. But all of them were fun miles, with zero commute, or in-town riding, so not bad . Only problem with the bike was an EXUP CEL when I exceeded 7K rpm for the first time, but I took care of it by adding slack to one of the EXUP valve cables. It might have the not uncommon oil pan leak, but not sure yet (could have been road oil). If it rears its ugly head next riding season, I'd fix it myself next winter. I'm changing the tires this week for Road5s, and changing the oil again, so it's ready for next year like a new bike. Just changed the Grab-On foam grips for proper ProGrip 717 ones, so bike is 100% sorted now.
theculturalattache
Post by theculturalattache on Oct 9, 2019 13:26:48 GMT -7
Do the pro grip grips really make that much of a difference?
I have the grip on ones at the moment.
theculturalattache
Post by theculturalattache on Oct 9, 2019 21:20:25 GMT -7
I have the grab on foam grips at moment.
daveinwoodland
Post by daveinwoodland on Oct 11, 2019 9:28:25 GMT -7
6K currently on my 2017, don't ride as much as I would like to and have no excuse living in a pretty much year round riding area. Still really haven't even broken In my new Michelin 5's but plan on riding today at least after all that crazy wind we had in Northern California. I think that mainly has to do with the blowhard in Sacramento
Post by Deleted on Oct 12, 2019 11:48:43 GMT -7
I have the grab on foam grips at moment. I ditched them for more proper grips, and couldn't be happier. The foam grips are too big for proper throttle blip while braking, even with my XL hands (or fingers, rather), plus did little to quell the vibes. The 717 grips look better than the more popular 719s, but seem to have a bit less cushioning, and should work better than the Grab-Ons IMO. I much rather have those, so will see how they work with vibrations on my next trip (next year for sure). They feel immensely better than stock, and I'm almost sure that's all I need in terms of cushioning vibes. If I need more, can always try the backordered 719s the following riding season, for less than $20. The 717s also seem more durable, by the way. The other good news is they're slightly larger than stock, which is just perfect now, since the stock ones leave quite a large gap to the barends, as you can see. These get to the large part of the barends, filling the space pefectly. The throttle I put it closer to the housing, and has no visible gap with the barend, while working perfectly. I destroyed the stock ones, to save time and aggravation, since I don't plan to ever put them back... and they're cheap, if future owner wanted to.
Finally, just got my new Road5 tires back (along with Bikemaster 90deg black valve stems), are all clean, and ready to be put on shortly. They're definitely taller, due to their more 'triangular' profile, which will undoubtedly make the bike turn in much easier. Will post initial impressions after I ride with them. Have a great weekend gang.
theculturalattache
Post by theculturalattache on Oct 12, 2019 16:13:28 GMT -7
elptxjc,
Thanks for the reply,
Cheers.
daveinwoodland
Post by daveinwoodland on Oct 13, 2019 9:51:39 GMT -7
I have the grab on foam grips at moment. Never have seen the "Lo" notice on the outside temp. Must be cold where you are?
gunnar
fabbin stuff...
Post by gunnar on Oct 13, 2019 15:21:08 GMT -7
That's engine temp, it's what I see when I turn the key on. It changes to a number when it gets above 120 degrees.
ubergreg
Post by ubergreg on Oct 18, 2019 23:58:54 GMT -7
Just under 11k and loving every mile. Took delivery in May 2019. Been to Europe twice, done a track day and use it as my daily. Only issue has been water ingress to the Smart LED turn signals (front). The noise this thing makes... What a bike.
mattemike
Post by mattemike on Oct 19, 2019 6:38:31 GMT -7
Virtually none. That will change soon when I get back to Florida for winter. Major upgrades to be installed, front forks, rear shock,ECU flash, 3/4 exhaust, frt & rear rotors & pads.
chesterburnet
Post by chesterburnet on Dec 2, 2019 22:36:46 GMT -7
0. I won't pick it up until Saturday.
vstate60
Post by vstate60 on Dec 2, 2019 22:52:43 GMT -7
Just under 11k and loving every mile. Took delivery in May 2019. Been to Europe twice, done a track day and use it as my daily. Only issue has been water ingress to the Smart LED turn signals (front). The noise this thing makes... What a bike. Atta boy! I’ve got 3.1k on mine and purchased mid August 2019. All commuting/hooligan riding on my side of town and not one true ‘trip’ yet. Need to change that soon.
vstate60
Post by vstate60 on Dec 2, 2019 22:53:20 GMT -7
0. I won't pick it up until Saturday. You’ll probably pee a little. For good and nervous reasons. Best bike ever, you did good.
jacoby
Post by jacoby on Dec 3, 2019 4:24:04 GMT -7
Right at 500 miles on my 2019. Just got it last month. What an awesome bike
