jgpapillon
Post by jgpapillon on Aug 25, 2019 11:05:21 GMT -7
I have just reached 600 miles on my 2019 MT10 and I need to adjust the chain. Could someone tell me what size socket I need to loosen up the wheel?
Thank you!
daveinwoodland
Post by daveinwoodland on Aug 25, 2019 11:45:21 GMT -7
32mm rear / 22mm front rear torque 137 ft lbs.
Post by Deleted on Aug 25, 2019 12:18:58 GMT -7
32mm. And in case it helps, 1/6th of a turn of the adjusting bolts tightens the chain about 10mm. If you mark where the nut is now with a permanent marker, you can back out both exactly the same amount, and keep the rear axle aligned. That's what I did. A few more tips: 1. Don't use too much force to measure slack. It's better to leave it a bit loose than too tight. 2. Do the right side first, so you don't add extra tension to the chain. Not a big deal, but it's better that way . 3. Don't rely on the rear stand spec (25-35). Checked yesterday, and it's not consistent. It showed 40 before adjustment (or +8), but only 23 after (or +1). Put it on the side stand, and it was in spec at 22. Just checked it now again, and it's 22, so will leave it there. Ideally I'd like it at 25 (right in the middle of 20-30), but it's not worth dicking with the adjustment back and forth IMO, especially when new; it'll keep loosening quicker than normal anyway, so better to adjust it at the lower end. From now on, will do exactly what I just did: wait until it's at the upper limit (or past a little), and adjust it 1/6th of a turn, which will put it at the lower end again, and call it a day. Finally, I personally think the factory torque spec for the nut is, well, nuts (ha ha). So I use 100, which is still more than any other bike I've owned... and they didn't have a locknut. I still need to use a breaker bar to loosen it. Anyway, just mentioned it, in case you wonder about that too, so you know you're not the only one . Hope this helps, brother.
Post by hooli on Aug 26, 2019 17:45:56 GMT -7
I reversed my rear axle so the nut is on the opposite side.
k1kingdom
Post by k1kingdom on Aug 31, 2019 21:24:15 GMT -7
Yes inddeed you are so right about the torque specs. The manual is very wrong. It cost me 80bucks total with shipping for a new wheel axle and locknut. Threads got messed up. When i get the new one i will use only 100ft lbs.
dilldough
Post by dilldough on Sept 1, 2019 17:09:40 GMT -7
I ruined 2 axles and axle nuts as well torquing it to 137 ftlbs. That spec may or may not be incorrect (seems really high), but i have not had any issues since greasing the mating service of the axle nut & washer. I believe the manual says to do hat but i had not been.
Post by mrcdharwood on Sept 2, 2019 0:19:09 GMT -7
I wonder too what pressure the manufacturer settings pit on the wheel bearings? Heard of a few failing over her in the UK.
