jacobsmith
Post by jacobsmith on Jul 29, 2019 15:36:54 GMT -7
I’m looking to know if I’m looking at any surprises when I change my left side engine cover as my got damaged and leaked oil from a high speed low side my engine and bar end sliders took most of the hit but the case was damaged
Post by RedAndBlack on Jul 29, 2019 18:30:20 GMT -7
I've replaced covers but never a crankshaft case cover so I'm not sure. But generally, you're going to lose a little bit of oil as the case opens. Make sure there's no dirt or debris inside. Buy a new gasket and take extra care with it never to bend or deform it. Make sure both surfaces are clean before you reinstall the case with the gasket between.
Post by evitzee on Jul 29, 2019 18:32:56 GMT -7
Yeah, just be careful when undoing it, buy a new gasket, and you might want to add engine case protection when you button it back up.
Post by Deleted on Jul 30, 2019 11:54:22 GMT -7
I'd also torque the bolts to spec, to avoid messing up the gasket, so look that up. You could post a pic of before and after, to see the damage. I don't have engine case protectors either, but do have frame and axle sliders. You shouldn't have any issues replacing that cover if nothing was messed up inside. Check everything carefully. Good luck.
jacobsmith
Post by jacobsmith on Jul 31, 2019 0:31:37 GMT -7
Thanks guys I was concerned with hidden springs or magnets etc. coming out as the damaged cover was removed that I could not see.
