oksuz
Post by oksuz on May 7, 2019 6:00:18 GMT -7
Hello, I want to ask something about mt10's display. My display is flashing like following video. Flashing issue (or not issue) can seeing at low light areas while engine running. How do I fix that ? What's yours ? * Battery changed and it is healthy, voltage is ok. my bike year is 2016(this video is slow motion for flashing action to be visible). youtube
Post by evitzee on May 7, 2019 7:30:18 GMT -7
It shouldn't be doing that. Check the connections, if that doesn't fix it have your dealer check it out, you might have a bad display.
oksuz
Post by oksuz on May 7, 2019 7:33:36 GMT -7
It shouldn't be doing that. Check the connections, if that doesn't fix it have your dealer check it out, you might have a bad display. which wirings ? can you explain ?
Post by evitzee on May 7, 2019 12:31:06 GMT -7
You'll want to check the connections to the display unit to make sure everything is tight. Look at the Service Manual.
fz10.org/thread/337/fz-10-service-manual-pdf
You can also adjust your brightness of the display, perhaps yours is set high and you are seeing some natural variation in the brightness. Tone it down a notch or two and see if that helps, it's shown in your owner's manual.
