blakbear
Post by blakbear on Apr 29, 2019 16:27:54 GMT -7
Hey Everyone, motor so far is doing good since the rebuild, time will tell i guess.
i purchased a Akra slip on, and i want to get the midpipe to go along with it aswell, naturally i wanted to get the power commander in lieu of the flash for warranty reasons. but i noticed on their website i only saw a stock exhaust map, nothing for the Akra slip on or the cat delete.
anyone know anything about this?
Post by Deleted on Apr 30, 2019 11:15:10 GMT -7
Good luck with the new engine, but you should be fine; yours was the only engine failure so far known to be a true defect. Finally, a stock exhaust map should be the same for a slip-on, since the stock can is straight-thru (no restriction).
blakbear
Post by blakbear on Apr 30, 2019 20:51:25 GMT -7
Good luck with the new engine, but you should be fine; yours was the only engine failure so far known to be a true defect. Finally, a stock exhaust map should be the same for a slip-on, since the stock can is straight-thru (no restriction). Yes, but i am planning on getting the Titanium mid pipe getting rid of the cat.
eldawso
Post by eldawso on Dec 14, 2020 1:05:28 GMT -7
LTTP, but how did you go? I'm in the same situation now with the link pipe and PCV.
