reyesfz
Post by reyesfz on Apr 23, 2019 18:37:54 GMT -7
So I had to replace the gasket on the clutch cover and now when I put everything back together my clutch cable almost does not have resistance at all. I am sure that the teeth on the pull rod are facing the rear of the vehicle. The pull rod itself is loose and just floating around. Is it supposed to be like that?
dertymt
Post by dertymt on Nov 10, 2019 2:19:58 GMT -7
im having the same issue right now after replacing my clutch pads/plates. Im sure the push rod is being grabbed by the clutch cover thingy but i have no pressure at all. . .followed the service manual to a T
